Activity › Forums › VEGAS Pro › Rendering as MPEG2 in Vegas 8 crashing computer
  • Rendering as MPEG2 in Vegas 8 crashing computer
    Posted by Kevin Caulfield on April 8, 2011 at 2:07 am
    I’ve never had this problem before but now, every time I try to render any Vegas 8 project as MPEG2 for Blu Ray, the rendering gets to about 15% and then crashes the computer (which is running Windows 7).
    When I render the audio component as AC3 that is fine. Also, I tried rendering the project as an AVI and that worked fine.
    I’m not sure why this is now happening. I’ve rendered successfully as MPEG2 files many times and burned Blu Rays.
    Does it sound like one of my settings has changed or something?
    John Rofrano replied 15 years, 5 months ago 4 Members · 7 Replies
  • 7 Replies
  • Steve Rhoden
    April 8, 2011 at 2:50 am
    Which recent program/s have you installed?
    Steve Rhoden
    (Cow Leader)
    Film Maker
    Filmex Creative Media.
    1-876-832-4956
  • Kevin Caulfield
    April 8, 2011 at 3:04 am
    Nothing I can remember. Although there was a Java update icon flashing the first few times this happened. It was asking me to update some Java thing. Eventually after about the third crash I did the Java update, but maybe that is causing the problem?
  • Stephen Mann
    April 8, 2011 at 3:58 am
    Does it always crash at the same point, or is it “approximate”?
    What are the crash symptoms? BSOD, Shutdown, Error message?
    Steve Mann
    MannMade Digital Video
    http://www.mmdv.com
  • Kevin Caulfield
    April 8, 2011 at 4:02 am
    Hi Steve,
    It seems to be approximately but not exactly the same point where it crashes.
    No blue screen, no error message. The computer just completely turns off with no warning.
  • Steve Rhoden
    April 8, 2011 at 4:29 am
    Oh no no no….Something else from Vegas is going on there.
    Do a system restore back a couple of days (even before the
    Java thing) and see if this shutdown still persists.
    Steve Rhoden
    (Cow Leader)
    Film Maker
    1-876-832-4956
  • Stephen Mann
    April 8, 2011 at 5:08 am
    “The computer just completely turns off with no warning.”
    This is almost always a cooling problem.
    Steve Mann
    http://www.mmdv.com
  • John Rofrano
    April 8, 2011 at 1:14 pm
    [Stephen Mann] “This is almost always a cooling problem.”
    Yea, try taking the door off the computer and point a fan at the insides and see if the render goes further. You might want to clean the dust out of your computer while you’re at it; especially between the fins of the CPU heat sink.
    ~jr
    http://www.johnrofrano.com
    http://www.vasst.com
