Activity Forums Maxon Cinema 4D Rendering as an animation gives me less particles than as an image.
  • Randy Johnson
    December 18, 2011 at 12:18 am
    Your emitter has both birth editor and birth render…. the render should be what you see.
    Particles are also dependent on the previous frame so if you started your render on frame 25 you will have missed the first 25 frames of emission … unless you started emission f 25 and so on. A way around this is to bake your particles. It does not take long and gets your particles to render the same every time.
    /Randy
  • Adam Rose
    December 18, 2011 at 6:55 am
    Ah yes I had different values for birth editor and birth render, thanks very much for the help 😀
