Activity Forums Apple Final Cut Pro Legacy Rendering and self contained
  • Rendering and self contained
    Posted by Craig Johnson on February 23, 2014 at 4:30 am
    Anyone encounter this? I have a few problem jpegs. There are 50 minutes worth in this project and 2 are beligerent. I have resized, changed them to png’s, cut them and brought them back in, basically have 20 or so hours trying to get them to render. I have them to the point where they play fine but still won’t render. I get the out of memory error box. If I were to make a self contained movie and it played, will it still be possible to encode and burn without playback issues? So frustrating.
    John Fishback replied 12 years, 6 months ago 4 Members · 5 Replies
  • Shane Ross
    February 23, 2014 at 6:38 am
    They need to be in the RGB color space, and not CMYK…and need to be under 4000 pixels on any side. Do these fit those parameters?
    Shane
    Little Frog Post
  • Craig Johnson
    February 23, 2014 at 2:51 pm
    Oh yeah. Been down that road too. All are RGB and 1440 x 1080. There are over a hundred other photos in this same timeline. All shot with the same camera, same settings. Crazy maddening. I did find a post online that someone claimed if the project file exceeded 100mb, the error would be triggered. I tried to get clarification as to what “project file” she was referring. No response from her. I doubt that conclusion but a drowning man will grab an anchor if you throw him one.
  • Nick Meyers
    February 24, 2014 at 10:58 am
    that would be the FCP project file you are working in.
    i doubt that’s the issue.
    but you could have a corrupt sequence,
    copy and paste the contents into a new timeline.
    it’ll mean a re-render, so maybe test the render on the trouble spots first.
    nick
  • Craig Johnson
    February 24, 2014 at 3:01 pm
    Yeah did that too. I have gone file by file and it comes down to 2 photos. Now I discovered if the cross dissolves are removed, one of the 2 render. Put it back and it won’t. Weird.
  • John Fishback
    February 25, 2014 at 4:36 pm
    Building on your self-contained idea, why not make a sequence with just those 2 images. Do your dissolve and then export a self-contained movie. Be sure to leave handles at either end. Finally, import into your main sequence.
    John
    MacPro 8-core 2.8GHz, 16 GB RAM, OS 10.8.4, QT10.1, Kona 3, Dual Cinema 23, ATI Radeon HD 5870, 24″ TV-Logic Monitor, ATTO ExpressSAS R380 RAID Adapter, PDE enclosure with 8-drive 6TB RAID 5
    FCS 3 (FCP 7.0.3, Motion 4.0.3, Comp 3.5.3, DVDSP 4.2.2, Color 1.5.3)
    FCP-X 10.0.9, Motion 5.0.7, Compressor 4.0.7
    Pro Tools HD 10 w SYNC IO & 192 Digital I/O, Yamaha DM1000, Millennia Media HV-3C, Neumann U87, Schoeps Mk41 mics, Genelec DSP Monitors, Prima CDQ120 ISDN
