Activity Forums Adobe Premiere Pro Rendering and Re Rendering
  • Rendering and Re Rendering
    Posted by Brett K on April 29, 2005 at 2:02 am
    Hi, just a question on premiere pro, is it normal that if you render a sequence on the timeline then when you then export it has to re render? shouldn’t it be able to use the render from the time line without re rendering?
    Mike Velte replied 21 years, 5 months ago 4 Members · 3 Replies
  • Aanarav Sareen
    April 29, 2005 at 5:17 am
    Premiere Pro renders the audio before exporting. If your video is already rendered, then PPRO should not have to render it again.
  • Scott
    April 29, 2005 at 6:26 am
    During the export it is assembling the final AVI from all the parts involved, including the previously rendered pieces. Anytime something needs to be computed is considered a render. In this case, assembling the non-rendered parts and the rendered parts to an AVI is considered “rendering”.
    Scott
    …Say that ten times fast…..
  • Mike Velte
    April 29, 2005 at 11:34 am
    Timeline renders are for previews only and have no other function, excpet some use these to export to tape. Exporting Mpeg, AVI’s or WMV;s does not use the rendered preview files.
