Activity › Forums › Adobe Premiere Pro › Rendering and Re-rendering in CS5 Premiere Pro
  • Rendering and Re-rendering in CS5 Premiere Pro
    Posted by Virgil Harper on January 25, 2011 at 10:26 pm
    I am using Adobe Premiere Pro CS5. When I render my timeline and save the project – close out and come back to the same project, there are quite a number of clips on the timeline that require me to re-render them. This happens every time. Not sure what is causing this.
    Any ideas would be welcome.
    Bob Dix replied 15 years, 8 months ago 2 Members · 5 Replies
  • Bob Dix
    January 26, 2011 at 8:57 pm
    Make sure you save the original render and never delete original clip file.
    Freelance Imaging & Video
    AUSTRALIA
  • Virgil Harper
    January 26, 2011 at 9:59 pm
    I keep the original rendered files. Haven’t deleted anything.
  • Bob Dix
    January 27, 2011 at 8:54 pm
    A mystery, did you manually save after each render, not automatically ? Try saving as a new project after render and see what happens ???????????????
    Good luck, you may have accidentally emptied the Media Cache ????????.
    Using an i7 Windows professional computer has happened at times not XP ?
    AUSTRALIA
  • Virgil Harper
    January 27, 2011 at 9:33 pm
    I do manually save the file. I will try saving under a new file name.
    I think there is some other issue unknown to me for why this is happening though.
    Virgil L. Harper
    Dir. / Cameraman
  • Bob Dix
    January 28, 2011 at 12:30 am
    Yes, save to a new project. It could be a blip between CS5 and the i7 computer 64 bit OS and approved video card ??????????????? you have probably defraged and run a disc check ? I would imagine you are running CS5 on a Quad Core with the minumum Adobe requirements ?
    You will fix it, good luck !
    AUSTRALIA
