Activity Forums Apple Final Cut Pro Legacy Rendering and multicam edits
  • Rendering and multicam edits
    Posted by Tracey Nole on June 7, 2010 at 7:29 pm
    I recorded a song performed by a band about 6 times using the same camera and tried to set up the tracks as a multicam edit.
    When I move it into the timeline from the viewer, it says it needs to be rendered. I render it, but as soon as I do something different, i need to render it again.
    Thoughts?
    Tracey
    John Pale replied 16 years, 3 months ago 4 Members · 4 Replies
  • John Fishback
    June 7, 2010 at 7:35 pm
    Sounds like your sequence settings don’t match the clip’s parameters. What are your seq settings & what are the clip parameters: codec, frame rate, frame size, etc.?
    John
    MacPro 8-core 2.8GHz 8 GB RAM OS 10.5.8 QT7.6.4 Kona 3 Dual Cinema 23 ATI Radeon HD 3870, 24″ TV-Logic Monitor, ATTO ExpressSAS R380 RAID Adapter, PDE enclosure with 8-drive 6TB RAID 5
    FCS 3 (FCP 7.0.2, Motion 4.0.2, Comp 3.5.2, DVDSP 4.2.2, Color 1.5.2)
  • Tracey Nole
    June 7, 2010 at 7:46 pm
    thanks for getting back to me. It was all captured from the same camera. I am assuming all the specs are the same but will check.
    Tracey
  • Shane Ross
    June 7, 2010 at 7:47 pm
    What kind of render bar are you getting? RED? GREEN?
    A multiclip means that you are trying to play back multiple STREAMS of video. Each angle is a stream. You are trying to play back SIX streams of video. That takes pretty fast hard drives. Firewire 800 won’t cut it. YOu need an eSATA raid, or internal SATA Raid of 3-4 drives. You need speed. When you don’t have that, FCP makes you render so that you are now playing back ONE stream, the render file.
    Get faster drives if you want 6 streams of video.
    Shane
  • John Pale
    June 7, 2010 at 8:36 pm
    Reduce the playback quality in the RT menu of your timeline.
