Activity Forums VEGAS Pro Rendering an MPEG 2
  • Rendering an MPEG 2
    Posted by Kathy Parton on September 1, 2011 at 2:49 pm
    I have Sony Vegas 9 movie maker, not the Pro version. I’m trying to render a video in MPEG 2 format using the “custom” settings. The custom button is not available. It does work for other settings including MPEG 1. Is there a way to customize the settings when rendering an MPEG 2 video? I need to adjust the bit rate. Thank you for any information.
    Kathy Parton replied 15 years ago 2 Members · 3 Replies
  • Mark Allen
    September 2, 2011 at 5:49 am
    It’s been a long time since I’ve used the non-pro version of Vegas but I believe losing the MPEG-2 custom button was one of its limitations. At least, that’s what I recall. Limited number of tracks I remember clearly (picture Edvard Munch’s The Scream). Losing some of the rendering custom buttons I believe was also a limitation.
  • Mark Allen
    September 2, 2011 at 8:10 am
    If you don’t mind a couple of extra steps to get your MPEG-2 output then a possible solution would be to output to a free lossless encoder format like Lagarith as an AVI file and then use an AVI to MPEG-2 converter to generate at your desired bitrate. I haven’t used it but TMPGenc can make the conversion. There are probably free MPEG-2 converters which can also do the job.
  • Kathy Parton
    September 3, 2011 at 4:47 am
    I was afraid of that. I guess I’ll just have to keep saving my money to go Pro. Thank you for you confirming yet another Movie Maker limitation.
