Activity › Forums › Apple Final Cut Pro Legacy › Rendering an Irregularly Shaped Video
  • Rendering an Irregularly Shaped Video
    Posted by Bill Brownstein on November 9, 2009 at 3:31 am
    This is an image of two 960×720 video files scaled down and placed next to eachother in FCP. What I’d like to know is if there’s a way to render this without any of the black? I don’t want the image to be distorted or cropped either. Is this possible?
    Tom Brooks replied 16 years, 10 months ago 6 Members · 10 Replies
  • 10 Replies
  • Jerry Hofmann
    November 9, 2009 at 3:43 am
    I’m confused..
    What is it you want to end up with? An aspect ratio which is only the red images? Or do you want to fill the screen size your picture is showing?
    Jerry
    Apple Certified Trainer
    Author: “Jerry Hofmann on Final Cut Pro 4” Click here
    8-Core 3.0 Intel Mac Pro, Dual 2 gig G5, AJA Kona SD, AJA Kona 2, Huge Systems Array UL3D, AJA Io HD, 17″ MBP, Matrox MXO, CD’s
  • Bill Brownstein
    November 9, 2009 at 3:45 am
    I want the final video file to be the aspect ratio of the red images; none of the black on the top and bottom.
  • Rafael Amador
    November 9, 2009 at 3:59 am
    You need to start by building a 16×9 sequence.
    rafael
    http://www.nagavideo.com
  • Bill Brownstein
    November 9, 2009 at 4:08 am
    Okay, do I keep all the presets the same or just check the anamorphic box? Keep in mind, I don’t want an anamorphic file (one that gets squeezed then unsqueezed by a DVD player) but a video file that’s undistorted and that shape. I’m not sure if this is even possible.
  • Mike Schrengohst
    November 9, 2009 at 4:11 am
    What is your delivery format?
  • Bill Brownstein
    November 9, 2009 at 4:21 am
    I’m rendering this to be uploaded online; that’s why I’d like it to not contain the “letterboxing” and just be the shape of the images.
  • Bret Williams
    November 9, 2009 at 4:32 am
    So just make a new sequence of the shape, and size you want. If your images are widescreen, then it would have to be 32:9. You’ll have to do your own math. I’d start with how wide you want it to be on your web page. Say, 1000 pixels. The height would be around 562 pixels. Make a 1000×562 seq with a STD codec like animation, and make it square pixels. Drop them in and export to whatever format desired. H.264 being the logical choice for qt or flv.
  • Bill Brownstein
    November 9, 2009 at 4:52 am
    wow, that was exactly what I needed to know. Thanks so much!
  • Rafael Amador
    November 9, 2009 at 5:10 pm
    [Jon Salimes] “Okay, do I keep all the presets the same or just check the anamorphic box?”
    Not Anamorphic.
    You have to do a 16×9 Square Pixels sequence.
    The sides must keep the 16×9 proportion.
    So you can choose any size which wide/heigh= 16×9.
    For example 160×90, or 640×360, or 1280×720, or..
    That will always look properly 16×9 in any computer screen or LCD monitor.
    rafael
    PS: Anamorphic is not a kind of pixel, but a way of displaying pixels.
  • Tom Brooks
    November 12, 2009 at 11:30 am
    To me, you already have what you need. Simply crop off the black parts when you export through Compressor, Squeeze, or whatever you use for final Web compression. Best to crop to dimensions divisible by 16, 8, or at least by 4.
