Activity Forums Adobe After Effects Rendering a vegas lighting effect
  • Rendering a vegas lighting effect
    Posted by Mark Still on October 3, 2008 at 11:37 am
    Has anyone encountered the following message(After Effects error vegas insufficient free memory) when trying to render a vegas light effect in After Effects?
    My system is an Intel dual core XP SP3 PC w/2gigs ram.
    M Still
    David Bogie replied 17 years, 11 months ago 2 Members · 1 Reply
  • David Bogie
    October 3, 2008 at 5:01 pm
    You mean you are using the Generate>Vegas filter?
    Or are you using a preset or project from someone called “Vegas Light”?
    Vegas can run into odd issues if you have not carefully designed the contours it attempts to sample.I’d suggest your artwork for the contours is at fault. Try another file, but, no, I have never encountered that error.
    “Free memory” in as AE error is completely misleading, heck, ALL AE errors are nonsense.
    bogiesan
