Activity Forums Maxon Cinema 4D Rendering a plane object as transparent
  • Rendering a plane object as transparent
    Posted by Scott Green on November 1, 2011 at 11:26 pm
    I’m animating these objects:
    And outputting a Quicktime movie with alpha but all I want it the objects and the shadows and for the plane (floor) to have alpha/transparency but I can’t figure out how to do it.
    I tried applying a compositing tag to the floor and deselecting ‘seen by camera’ but this didn’t work as it would output the shadows.
    Can you help?
    Thanks.
    I really do love good design – https://www.splurj.com
    Scott Green replied 11 years, 8 months ago 2 Members · 6 Replies
  • Adam Trachtenberg
    November 2, 2011 at 4:40 am
    There is a very handy little shadow catcher plugin that’s free — you can probably find it with a google search.
    In this case, however, you can do it another way. Render an object buffer for everything but the floor and also render a shadow pass and a diffuse pass. Then, in post, use the buffer to knock out the floor from the diffuse pass, and multiply the shadow pass over everything.
  • Scott Green
    November 2, 2011 at 8:48 am
    I’ll try and make sense of that later and let you know how I get on 🙂
    Thanks.
  • Scott Green
    November 2, 2011 at 8:49 am
    Does anyone have any simpler solutions? I’m a bit of a novice 🙂
  • Adam Trachtenberg
    November 2, 2011 at 8:33 pm
    Well, like I said, the simplest solution is the shadow catcher plugin, but what I described really isn’t that complicated. Here’s a video tutorial walkthrough: https://www.3danvil.com/tutorials/Shadowcatcher/Shadow%20Catcher.html
  • Scott Green
    November 3, 2011 at 7:56 pm
    Wow, that really was easier than it sounded, thanks Adam 🙂
  • Scott Green
    January 9, 2015 at 3:43 pm
    Wow, it’s been a while since I first wrote this post, but I today I’m still having trouble with outputting shadows and alpha with Shadow Catcher.
    What I want to achieve is:
    Where everything is orange in this image I want to be Alpha. The spheres bob up and down with the plane hiding the underneath of the objects but i want the shadows on the plane.
    But when I apply Shadow Catcher the the alpha channel of the material applied to the plane I can see through the plane but i don’t want to:
    Anyone got any ideas?
    Splurj Creative Motion Graphics, Animation & Video Production in Manchester UK.
