Activity Forums VEGAS Pro Rendering a part of project
  • Rendering a part of project
    Posted by James Fox on November 10, 2010 at 8:19 am
    Hi!
    Can I render a part of project in Sony Vegas?
    For example, I have a 20 minutes edited project, and I want to render it into 2 parts.
    Problem came up as I cant find a place to upload over 15min videos.
    James
    James Fox replied 15 years, 10 months ago 3 Members · 4 Replies
  • Graham Bernard
    November 10, 2010 at 1:22 pm
    Using VP10 or 9?
    Create 2 regions 10mins each and then use Batch Render Script (Tools)
    , select Region and you\\\’ll end up with what you want.
    Grazie
  • James Fox
    November 10, 2010 at 1:29 pm
    yes thanks, I used Vegas pro 9. Created region and put a tick in rendering box to render only region 🙂
  • Danny Hays
    November 10, 2010 at 4:52 pm
    Just setup your loop area, yellow triangles top of timeline, then render, check box, render looped region only. Hope this helps, Danny Hays
  • James Fox
    November 11, 2010 at 10:06 am
    aah thanks alot about those yellow triangles 🙂 I tried to mess with those triangles, because i remembered from my first rendering that i rendered accidentally only a part then. Just didnt know about the tick needed in rendering box!
    Btw, whats the difference between region and yellow triangles then? Which to use when?
    Many thanks,
    James
