Rendering A Long Movie In Sony Vegas 11
John Rofrano replied 12 years, 2 months ago 9 Members · 17 Replies
Jude Alexander
October 18, 2012 at 12:35 amHey Guys,
The rendering went great! Got the file down to 6.3GB and the audio just shy of 200MB
The weird thing now is, when I import it into DVDA, It’s telling me the project size is 9.01GB
It recognises that I’m using a Dual Layer disc and even though I know DVDA’s size estimates are usually off, it still won’t let me burn the movie. Or it will start burning, then say, it needs a 2nd layer break and when I can’t insert one-it cancels the whole thing.Have you guys encountered this before? Is there something in DVDA that adds to the file size?
Kieran Kirkwood
October 30, 2012 at 10:00 amrender it as a .avi (video for windows) then see how big that is.
Mary Alexandra
October 31, 2012 at 11:36 pmYou might select all & copy & paste this to a document.
Try following one of this youtuber’s tutorials.
His main channel page is:https://www.youtube.com/guerillabill
You can select “Browse videos” then in the search box type in “DVD Architect” to pull up some options for creating your movie on to a disk, also you can shoot him a direct message from your channel to his, to ask any quick questions if you get stuck.
Here is a great one to simplify what you’re aiming to do in DVD Architect.
https://www.youtube.com/watch?v=ucXeK3o-9Og&feature=plcp
FYI: I’m not a close personal friend of his, but have been using a lot of his tutorials to teach myself video editing in the Sony Vegas Movie Studio program & when I’ve gotten stuck somewhere, I’ve sent a quick message & he’s sent back an answer in a very short time. My Sony program also has the DVD Architect, but I’m not there yet, I plan to learn that after I’ve done some heavy video editing & saved 700+ movies to disks on a smaller sized format mainly to watch on my 17+” laptop, not the home TV/DVD setup. When I finish, I’ll select the fav’s to make a library for that.
Also, I’m not sure if you know this (I just found out last week) but I would pick up a pack of the larger capacity DVD’s they now make at the 8.5GB size. This size disk is also GREAT for saving some of the files that clutter your computer in the event you have a PC crash or just want to free some space. You can store your music library, documents, PDF’s, photo’s & videos there as well. I used a USB to store a ton of stuff & the drive stopped working due to some corruption ugh. (I lost 16GB of data) so from that hard lesson, I’ve just thrown all my stuff on the larger capacity DVD, then labeled with a sharpie the date & whatever I saved there IE; “music & movies” or whatever I was storing. Plus, until you become seasoned at rendering, it allows you to save some vid’s that end up a perfect size & quality that end up a tiny bit over the standard DVD size. I went to a lot of trouble to create a few vids that were the perfect quality, size of dimensions & saw after the render, the GB size over the standard & I didn’t have to be an expert at the rendering & creation process. It allowed me some extra leeway which was great.
Price ranges I found (to give you an idea of cost) for the 8.5GB larger capacity DVD:
#25-pack is apx. $24.99 (MicroCenter)
https://www.microcenter.com/product/260003/DVDR_DL_8x_85GB-240_Minute_Disc_25-Pack_Spindleor
#50-pack $40.95 (Best Buy)
https://www.bestbuy.com/site/TDK+-+DVD+Recordable+Media+-+DVD%2BR+DL+-+8x+-+8.50+GB+-+50+Pack+Spindle/4408457.p;jsessionid=F37FBF4755697B2EDC1FEBEE1958593A.bbolsp-app01-28?id=1218476995113&skuId=4408457&st=8.5gb&cp=1&lp=2I would grab a pack, I’m sure you will use up all of them over time, especially if you plan to continue using that video camera you mentioned that you have. Plus, after knowing how to render & save them, I’m sure this would motivate you to use your video camera more often & save some great memories of whatever you film.
I wish I knew what your movie was of. A wedding? Your family? A concert? Also, how do you want to play it back? On your home TV/DVD setup in your living room or just on your computer? What size is your computer screen? Choosing standard smaller formats are good for screens at or near the 15″. If your PC is larger like 17+”, then I will share my preferred rendering settings in the Sony Vegas Movie Studio program.
I would use the DVD Architect to create a disk for versatility, that plays both your computer and your home TV/DVD living room setup. But just for compression & saving for computer playback from a disk, these options are specifically for this.
Note: When you are in the “render as” area window, for each item you click on once, look below at the description below it, it should read what that format is best used for. I have a slightly different version of Sony Vegas, but most of this below should come up similarly to my program compared to your Vegas version.
Examples:
These are for computer playback from your CD-Rom disk, in a higher quality format, that should fit on your DVD disk.1. Select File>Render As
2. Enter in “Name” of your movie/video & the folder you want to save it in.
3. Find “Windows Media Video V11 (.wmv)”
4. Choose the 3 Mbps
5. See below it, the description that should read “Use this setting for high-quality video playback from a CD-Rom. (preset at) Audio: 96 Kbps, 44,100 Hz, 16 Bit Stereo WMA, Vieo: 30 fps, (size) 640×480
6. Keep your selection on the “3 Mbps” then,
7. Scroll down a bit to locate & select the “customize template” button, to pull up a new window of options.
8. Select the tab “Video.”
9. In the “Image” drop down, I would either select the
* (Preset size & quality) at “HD 1280×720” (larger dimensions, quality & size)OR (my fav settings for computer CD-Rom play back)
My favorite is between the smaller 640×480 & the larger 1280×720 preset size. Here it is:
10. In the “Video” tab, in the drop down, select “Custom”
11. Width: 840
12. Height: 480
13. Go to the tab “Project”
14. Find “Video rendering quality” & select “Best.”
15. Name at the top, the new customization template
(I named it “3 Mbps Custom 840×480 BEST 4 CD Rom.”
16. Click on the right where you entered the custom format name hit the little picture of the floppy disk to save it.Remember, the best settings for playback from a CD-Rom, aren’t the best render settings for uploading the video to youtube, which you can also make another rendering for if you wish to do so.
For uploading to youtube, I prefer: (with your video in the Sony Vegas a) drag your “MTS” file to the Vegas’ “Project Media” area. Then select that dropped media in the project media area & drag it to the timeline beneath area, in the Video & Sound areas.
1. File>Render as
2. MainConcept AVC/AAC (*.mp4)
3. Choose below, Internet HD 720p (size is 1280×720) as a preset option but I think is too large of GB total, so
4. Click on this “Internet HD 720p”, then find beneath, the “customize” button & click on it.
5. In the video tab, in the “Frame Size” drop down, I would choose either “Multimedia 480×360” or “Miltimedia wide 640×360” (nice & small) if you like (prefer) either of these.
My fav, is in the “Frame size” choose “custom frame size” in the drop down “854×480” which I find to be perfect in GB size & window size for storing & uploading to youtube.
Just enter in manually Width: 840 & Height: 480The smaller sizes work fine if all you’re doing it storing the video as a backup & for sharing.
6. Then finish it off in the “Project” tab by dropping down in the “Video rendering quality” by choosing “Best.”
7. Then name this customization at the top as, (my example) the settings info. “Internet HD CustomBEST” (include the dimensions you chose, peek back in the “Video” tab to view what dimensions were that you set up ”____x_____” with any part of that dimensions description like “multimd” “multimdWD” or just “HD”
So the example name:
Internet HD CustomBEST 840×480 /
Internet HD CustomBEST 840x480MultWDor choose what makes sense for you when naming the template to reuse later.
8. Then click next-to the “template” at the top, where you made the new customized template name, don’t forget to click the tiny picture of the floppy disk, to save your settings. This way, if you love the results & want to sharp shoot your next project, you have one setting for youtube uploading & one for direct CD-Rom playback to your (& others) PC from the disk.
Remember, as you fiddle in the Sony Vegas Movie Studio with the timeline, you can hit the “S” key wherever you want to “split” your video, I would make one test video by splitting off 3/4 or the video & leave about 15 minutes only in the timeline, delete the 3/4 keep the 1/4 (or 15 minutes) then “save as” TEST VIDEO then fiddle with rendering one short video to different formats, then see what size in GB it turns out to be when it’s done rendering. Then watch it to see how you like the clarity, window size & file size, without wasting waiting time for rendering the entire 2+ hours only to start over again trying out another setting if you want to test 3 to 4 formats, before choosing which you like best. After creating a few test vids, watch them & choose which look best to you then calculate the total 15 minutes at that size, multiplying your vid length, to come up with the estimation for what size yours will turn out to be after it’s finished rendering.
After creating a few different 15 minute test video’s & doing the calculations, you will then know, which one is the playback size window & volume of the GB size for the vid’s length. Then you’re able to choose which one to use as a master for youtube, for Architect & for playback from a disk on the PC.
Also remember that youtuber’s channel (maybe subscribe) to keep handy any “how to’s” you love best. You can also save some of the favorite “how to” tutorials using the https://www.keepvid.com site, (no downloading the program & it’s free) this keepvid allows you to copy any youtube video straight to your computer. If you use this (I do all the time) it will require you to download “Java” (go to their website for safety) It’s only a tiny program almost all computers end up needing/using as a standard. When saving the how to vids to your PC using keepvid, after pasting the video link, I would select the blue colored one “mp4 (max 480p) as most PC’s can playback vid’s with the mp4 format taking little space. I’d make a folder in your “documents” named “Tutorial Videos” (or whatever you like) for storing teaching vids to use while you’re using Sony Vegas doing projects. Plus, if your internet is either slow or down, you won’t have to rely on that or streaming or searching to find that fav video, even sometimes seeing it’s been removed.
Hope this helps!
Some contents or functionalities here are not available due to your cookie preferences!This happens because the functionality/content marked as “Google Youtube” uses cookies that you choosed to keep disabled. In order to view this content or use this functionality, please enable cookies: click here to open your cookie preferences.
Jesse Solorio
June 3, 2014 at 2:11 amI am done editing a wedding video that’s about an 1hr:54 min on Sony Vegas Pro 10. The original video was recorder on a Sony MiniDV cassette camcorder. Now my dilemma is how to set the rendering settings and how to burn it directly from Vegas pro onto a DVD. I am just trying to render the video so to ensure its maximum playback compatibility with most commercial DVD players out there and also to set the frame properly to be seen on variable TV screens without the frame being trimmed because of the settings before rendering/burning to DVD. I realized that I needed more DVD space after attempting to burn it onto a 4.7gb DVD thus I went out and bought a 25pck of Memorex Dual Layer DVD+R 8.5GB/240min. It’s a wedding video so I am trying my hardest to make it look/sound its best quality, I know Blu-ray is better but I do not have a bluray burner. I have a philips DVD+R Double layer 8x drive. Are there options to try compressing the file since its a large one to make it fit onto my 8.5Gb DVD’s. After attempting to burn it directly from Sony Vegas it tells me that the image file is to big and to adjust the rendering settings to make it fit on my DVD. Any help would be greatly appreciated as I am COMPLETELY NEW to Sony Vegas and setting parameters/frames/rendering settings on how to export your videos and burn them onto a Double layer DVD.
John Rofrano
June 4, 2014 at 1:02 am[Jesse Solorio] “After attempting to burn it directly from Sony Vegas it tells me that the image file is to big and to adjust the rendering settings to make it fit on my DVD. “
It might be that the Timeline Burn function only supports single-layer 4.7GB DVD’s. I couldn’t find anything in documentation to suggest this but it it appears to not like you going over 4.7GB. I know that DVD Architect definitely supports double-layer 8.5GB DVD’s. You may need DVD Architect in order to burn a double-layer discs.
~jr
http://www.johnrofrano.com
http://www.vasst.com -
Jesse Solorio
June 15, 2014 at 4:08 amThanks for the reply, it looks like I can now burn my 1:55min video onto a 4.7GB DVD but can only be viewed on my desktop computer and not in my DVD, When I insert the DVD for playback into my DVD Player it say’s “Disk unknown” So I think I am still formatting it wrong to where my commercial DVD Player does not recognize it. The last time I render my 1:55min video I formatted as:
Main Concept MPEG2
Output Type: DVD
Width: 720X480
Frame Rate: 30
Aspect Ratio: 16X9Project Properties:
Custom (1920×1080, 29.970 fps)
Field Order: None (progressive scan)
Pixel Aspect Ratio: 1.0000 (Square)
Output Rotation: 0
Format Rate: 29.970 NTSC
Pixel Format: 8bit
Video Quality: HighAnything I am doing wrong here?. The issue here that I am dreadfully needing help with is with the rendering settings and Project Properties settings to where the DVD can be viewed and compatible with most commercial DVD players out there without the video suffering video and sound quality. I am also afraid that the settings I am choosing to render my video with will either be to big or too small for it to be viewed say perhaps on a 47in screen TV. Any help on settings and format I should use while I render my video will be greatly appreciated.
John Rofrano
June 15, 2014 at 12:57 pmIt may be your media.
What type of DVD’s are you using? Are they DVD-R? DVD+R? DVD-RW? Not all commercial DVD players will play all discs.
Also what brand? Stay away fro cheap media like Memorex. I only use Taiyo Yuden/JVC, or Verbatim and only the high end discs, not the “value line” discs.
Try using a high quality DVD-R disk. These are the most compatible.
~jr
