Activity Forums Maxon Cinema 4D Rendering a Huge Image with Tiled Camera
  • Rendering a Huge Image with Tiled Camera
    Posted by Jarratt Moody on November 11, 2009 at 8:22 pm
    I’ve rendered large images using Tiled Camera before, but I now need to create an image for an airport window cling that’s 559.75 in x 82.5 in at 50 ppi.
    It looks like Cinema is topping out at 16000 pixels. This image needs to be 27,988 pixels wide. I thought Tiled Camera could handle it, but it looks like Cinema first decides the image will be clipped, and then renders out the 4 tiles of the already clipped image. In the render settings under resolution there is a warning that “Resolution Clipping Applies!” I’m at a loss for solutions
    Can it be done?
    Mark Walczak replied 16 years, 10 months ago 3 Members · 4 Replies
  • Jarratt Moody
    November 11, 2009 at 11:51 pm
    I found a hacky solution for those that run into this issue. You can make a tiled camera referencing your main camera and just create a new camera using each of the 4 positions of the tiled cam. Render using those cameras and stitch later. Not incredibly pretty, but it works.
  • Lennart Wåhlin
    November 12, 2009 at 1:52 am
    But if you tile (Using the Tiled cam) 4×4
    then you should make your output half size.
    (Width /2 and Height/2) or you will end up
    with 4 renders -each- 27988 pixels wide.
    Cheers
    Lennart
    aka tcastudios
  • Jarratt Moody
    November 12, 2009 at 2:19 am
    Ah, good point. I, like so many others on creative cow, must conclude that I am an idiot. Thanks for humoring.
  • Mark Walczak
    November 17, 2009 at 5:42 pm
    Great point, Lennart. That is a real “gotcha”!
    What makes you explode?
    http://www.explosivegraffix.com
