Activity Forums Blackmagic Design Rendering a dv clip in premiere pro
  • Rendering a dv clip in premiere pro
    Posted by Sameer Shrivastava on September 24, 2005 at 9:02 pm
    Hi, i am upgrading a large time line from dg beta pal tapes but have some dv clips in it also. i captured the dv clips through firewire. they were fine, but when i color corrected them they jittered. but when i selected reverse field order on the field option again they were ok. please explain. is it a driver problem 5.1
    i understand dv is bottom field first and rest upper field first.
    sameer
    Luke Maslen replied 20 years, 11 months ago 2 Members · 3 Replies
  • Luke Maslen
    September 26, 2005 at 4:10 am
    Hi kjasdf,
    Please review the support note DV clips in PAL format look weird. The DeckLink 5.1 Windows drivers should be fine to use with PAL DV but there are general field order issues with PAL DV which are often exposed when applying effects including color correction. The support note provides some details regarding this.
    Regards,
    Luke Maslen
    Blackmagic Design
  • Luke Maslen
    Hi Sameer,
    Regards,
    Luke Maslen
    Blackmagic Design
  • Luke Maslen
    September 26, 2005 at 4:12 am
    Ooops, my apology for completely mistyping your name. Next time I’ll look at the keyboard!
    Regards,
    Luke Maslen
    Blackmagic Design
