Activity Forums VEGAS Pro Rendering a 1080p project to DVD
  • Rendering a 1080p project to DVD
    Posted by Karen on February 18, 2014 at 5:05 pm
    I hope someone can help. I have a project shot in 1080p. I’m working on a pc with Vegas 12 and have edited the project. It has multiple files that are about 3 min. each – making the total project length about 1 1/2 hours.
    I need to deliver the project to the client in a DVD and via youtube. The 1080p render for youtube works fine (unlike the DVD project these are not lumped together but are separate uploades) but I cannot seem to get any good looking results trying to render the 1080p files using the DVDA preset for mpeg2. It looks very bad – pixalated, fuzzy, just plain terrible. I’ve tried converting the file to NTSC Widescreen 720×480 but it is still awful.
    Even renders in 1080p format will often freeze at various points causing non response from vegas and task manager end process. I’v shut down GPU acceleration and the render goes faster but still looks like crap.
    Any Advice???
    I’m running a quad core i7/16 gb ram, 64 bit, windows 8 system – nvidia geforce gtx 680. I’ve never had trouble before…
    Float Pave replied 12 years, 6 months ago 5 Members · 6 Replies
  • Abhi Nash
    February 19, 2014 at 5:33 pm
    Wait…
    1.Do you want to write 1080p in 1080p into DVDs?
    First of all,convert the video to 720×576 using Handbrake.
    Download Nero(The Trial) and use it to burn the DVD,It won’t lose much quality.
    Or you could try “DVD Architect” from Sony.
  • Karen
    February 19, 2014 at 7:44 pm
    Thank You for responding.
    I was under the impression that you could not write 1080p to DVD.
    I need to create a standard definition DVD from the 1080p edit. The client is ordering dvd’s for distribution and they do not have BlueRay Players…The source video is 1080p AVCHD. When I have changed the project properties (In Vegas)to SD 720×480 and rendered to DVD Architect NTSC Widescreen the renders never work and always hang/freeze at various placing forcing a task manager end program.
    I’ve rebooted, but it never works. I’ve even used other dvd (AVS Converter 8) software to convert from 1080p to 720×480 SD and it still looks very bad. I already have Handbreak…but thought that since it did not work with AVS that it would not work with Handbreak.
    Clearly I must be doing something wrong…but I do not know what that is.
    I’ve been running this system for about a year and have never had this issue…SD or HD video has always been fine. Can the graphic card be an issue?
  • Stephen Mann
    February 19, 2014 at 10:47 pm
    DVD is *by definition* 720×480 pixels. After viewing it in 1080, 720 will look worse.
    Steve Mann
    MannMade Digital Video
    http://www.mmdv.com
  • Thayalan Paramasawam
    February 20, 2014 at 1:52 am
    Hi……
    (Abhi Nash)Download Nero(The Trial).
    Nero is not good our working station especially if you use SVP for editing.Check this link below,adivice Mr.John Rofrano…..
    https://forums.creativecow.net/readpost/24/958953
    System Details:
    Custom Built
    Working Station 1) – Motherboard – Asus M4A78 Plus,Processor – Amd Phenom llx4 945 Black Edition,Ram – 4GB,Graphic Card – Ati Radeon HD 5990,Dvd Writer – Plextor PX-890SA,Operating system – Window 7 Pro 32 bit and Editing Programe -Sony Vegas Pro 10
    Working Station 2) – Motherboard – Asus M4A88T-V-EVO Series,Processor – Amd Phenom llx4 955 3.2GHZ Black Edition,Ram – 16 GB,Graphic Card – Asus HD 6770 1GB DDR 5,Blu Ray Writer – Plextor PX-B950SA,Operating System – Window 7 Pro 64 Bit and Editing Programe – Sony Vegas Pro 11
    Working Station 3) – Motherboard – Asus M5A99X-EVO,Processor – Amd FX 8350 4.0/4.2 GHZ,Ram – 16 GB,Graphic Card – Asus Gtx 650 1GB DDR 5,Blu Ray Writer – Plextor PX-B950SA,Operating System – Window 7 Pro 64 Bit and Editing Programe – Sony Vegas Pro 12
    February 20, 2014 at 2:01 am
    hi….
    1)(Karen)the renders never work and always hang/freeze at various placing forcing a task manager end program.
    Try to off the GPU ACCELELERATION.Sure its will work….
    2)Post your project setting.
    System Details:
    Custom Built
  • Float Pave
    February 25, 2014 at 4:25 am
    Give AppGeeker DVD Creator a go,I have beening using it for years, it is a all in one stop.
    You don’t need to convert the file from 1080p to 720p, the utility can automatically convert the video and then burn onto DVD for you.
    https://www.appgeeker.com/convert/burn-mts-to-dvd.html
    If you try it, tell me how is the output quality of DVD video.
