Activity › Forums › Apple Final Cut Pro › Rendering
  • Posted by James Ewart on September 9, 2014 at 2:45 pm
    Despite rendering and re rendering I am still dropping frames in proxy mode and there arrested orange bars in the timeline as is the case when I switch to Optimised Media and try and render that out. Something is clearly not rendering out.
    Not such a big deal as it will render overeating out during export I hope but which render files can I trash if I want to clean it up and render everything once and for all please? And is there any advantage to doing this I’m sure I read somewhere it was a good idea.
    And what is in the ‘High Quality Media” folder please?
    Thanks you in advance
    James
    Jeremy Garchow replied 12 years ago 3 Members · 3 Replies
  • Robin S. kurz
    September 9, 2014 at 2:52 pm
    [James Ewart] “which render files can I trash”
    It’s all or nothing. And it sounds like you’ll want to try that and restart.
    [James Ewart] “what is in the ‘High Quality Media” folder”
    Your optimised media.
  • James Ewart
    September 9, 2014 at 2:58 pm
    Thank you.
    I have a transcoded Media folder with my Proxy and Optimised media in it in the bundle. I have an Original Media folder too.
    What I have not seen before is a High Quality Media folder within my Render files folder.
    Does not seem to contain media as such, just a bunch of folders containing gobbledegook “Frame references”
    Regards
    James
  • Jeremy Garchow
    September 9, 2014 at 4:34 pm
    [James Ewart] “What I have not seen before is a High Quality Media folder within my Render files folder.”
    Those are the render files. Your Project settings specify a rendering codec (usually ProRes).
    With the Project area selected (command-2), hit command-j.
    This should open the info window in the inspector for that Project. Click the modify settings button.
    In there, you will see a drop down menu called “render format”. That is the rendering settings for your timeline.
    If those render files are on a drive that isn’t quite fast enough to playback whatever you have selected there, you might see dropped frames.
    Jeremy
