Activity Forums Adobe After Effects rendering 720P
  • rendering 720P
    Posted by Matt Jones on January 28, 2009 at 4:50 pm
    I’m working on getting an output template set for digital delivery at a local TV station.
    The comp is set up as 1080i (1920×1080) I’m outputting it for station #1 as DVCproHD file. Work’s great, it’s their native playback format.
    Station #2’s native format is 720P H264 @ 59.94. So I need to:
    1. change the field order from UFF to none-progressive
    2. the Framerate from 29.97 to 59.94
    3. change the size from 1920×1080 to 1280×720
    4. save as H264 instead of DVCProHD
    Can I just do this with a different render setting and output module? Is this the best way (highest quality) to do this?
    Matt
    Matt Jones replied 17 years, 7 months ago 26,441 Members · 1 Reply
  • Matt Jones
    January 28, 2009 at 6:33 pm
    Thanks Dave,
    My primary editing app is Media100HD, but I have FCS as well and will check into the “droplet” work flow you suggested.
