Activity Forums VEGAS Pro Rendering 4K Footage — Major Issues
  • Rendering 4K Footage — Major Issues
    Posted by Devin Olson on May 8, 2014 at 8:03 pm
    I’m working on a project for a client at the moment and shot it with my GH4s in 4K. Editing works fantastic in Vegas Pro 13, but when I render, major issues.
    Have tried WMV, AVI, and XAVC (what is this format compatible with? Can’t watch and can’t upload to YouTube?). Every time, I either get a video with jumbled frames and a ton of black frames, or the render fails with this message even though memory use is only at 25-35%:
    “An error occurred while creating the media file…
    The system is low on memory. You may be able to reduce memory usage by closing other applications.”
    Here’s an example of what it looks like:
    https://youtu.be/MuwrZdUpEEw
    I have a Dell XPS 8500 with an Intel Core i7-3770 CPU @ 3.40GHz, 24 gigs of RAM, and a 64-bit operating system.
    It seems like I’ve tried every possible combination of render settings for 4K, but maybe I’m missing something.
    Vegas seems to be doing this with 2048×1080 video as well, but not 1920×1080.
    Roger Whiting replied 11 years, 6 months ago 2 Members · 2 Replies
  • Devin Olson
    May 10, 2014 at 4:39 am
    For anyone needing a fix for this same problem, I think I may have just found the solution.
    Options > Preferences > Video > GPU acceleration of video processing > Off!
    Seems to be working now!
  • Roger Whiting
    March 1, 2015 at 5:25 pm
    What are you using for your video settings for uploading a 4k video on youtube?
