Activity Forums VEGAS Pro Rendering
  • Rendering
    Posted by Morty Aronsen on November 25, 2008 at 8:06 am
    Hello!
    I just wonder what the best rendering settings are for dvd.. I know it`s mpeg 2, but what bitrate should I Choose? I usually pick constant bitrate 8000. Is that ok, or is it other settings I should consider?
    What are the best settings if I want to show my movie on a pc?
    I`m going to show a movie on a projector.. Is it the same if I`m making a file for windows mediaplayer or if I`m burning it to a DVD?
    M
    John Rofrano replied 17 years, 9 months ago 2 Members · 1 Reply
  • John Rofrano
    November 25, 2008 at 12:22 pm
    Just use the DVD Architect templates that are in Vegas. They are already set up to give good quality.
    That’s fine as long as your movie doesn’t get too large to fit on a DVD. Then you would want to consider using a variable bit rate.
    What will you use to show it? DVD’s will be interlaced (unless you render progressive 24p) and all DVD player software will deinterlace the footage for you so it shouldn’t matter. If you just play the raw files, some media players will not know to deinterlace so stick with DVD player software.
    If the original footage is standard definition then WMV or DVD MPEG2 will not matter. If the footage is HD then WMV playback on a PC will give you better quality specifically for use with a projector but don’t go above the resolution of the projector which is sometimes surprisingly low for the cheaper models.
    ~jr
    http://www.johnrofrano.com
    http://www.vasst.com
