Activity Forums Adobe After Effects Rendering 3d Shadows with transparency
  • Rendering 3d Shadows with transparency
    Posted by Ross Gerbasi on May 24, 2007 at 4:06 pm
    Ok, so I have checked around for info on getting a 3D comp to have floor shadows only.
    The solution seems to be making a white solid, matching it up to the floor, and having it accept shadows, then changing the blend mode to Multiply.
    Cool that looks great when I have a background behind the comp. BUT now I wanna take this composition and render it out using millions+ for transparent video in flash. The catch is I need that shadow attached to it. When I turn off my background layer to go transparent with everything I, ofcourse, see the white solid again.
    Is there any way to make a 3d object only receive shadows? So nothing but the shadow will show, that does not involve blending modes. That will support exporting.
    Any help? thanks guys!
    -ross
    Steven Kutny replied 18 years ago 2 Members · 2 Replies
  • Ross Gerbasi
    May 24, 2007 at 10:59 pm
    Dave thanks for posting! 🙂 I know I am new here and some of your posts have saved me a crap load of time. Your totally right, but I was really just looking for a solution to the problem.
    Actually it ended up being quicker to just do it that way, the old copy, color and flip.
    BUT for anyone wondering. I did find a solution.
    Start with
    Some comp with a 3d character or something that you want to cast shadows.
    New White Solid.
    Make it 3d.
    Make a light.
    On your character set the material options to Cast Shadows and not to accept light or shadows.
    Set the white solid to accept shadows, not lights and not cast shadows.
    Position in the scene as a floor and Pre-Comp as Floor.
    Collapse Transforms
    Inside Floor comp set mode to Silhoutte Luma
    Back in the main comp make sure you have some background behind the floor. (Black Solid will do it)
    The Siloutte Luma will cut into the Black Solid giving you transparency with just a shadow. If you need other parts of your scene rendered just go back into the floor clip and create more white solids to take up space.
    Your layers should look like this
    Main Comp
    Light
    Character
    Floor Comp
    Black Solid
    Floor Comp
    White Solid for Floor (silhoutte luma)
    Other Solid for wall
    🙂 Hope this makes sense, and I know its madness… So honestly Black solid and feather mask is a good solution 🙂 Or Copy comp, tweak and blur… But for those as crazy as me… here is a trick.
    thanks
    -ross
  • Steven Kutny
    August 29, 2008 at 9:17 pm
    wow, this is huge to me, a great tip! thanks so much for finding a solution and posting back to your original question.
    Steve
    Steven Kutny
    Digital Artist
    http://www.stevenkutny.com
