  • Posted by Richard Rodriguez on July 26, 2007 at 4:06 pm
    Hello,
    Have FCP 6 with a Dual Quad Mac Pro, 8 GB Ram.
    I have a program with 2 alpha channels, 6 stills with movement (scale and position), 4 picts with Alpha with movement and scaling, 4 titles that scale into position, stereo music and voice over track. The problem is i can’t get real time previews without having to continue rendering everytime the client makes a minor change. We have the AJA Kona Card. Shoudn’t this give the real time capabilities? What is the solution?
    Big Rich
    BIG RICH
    Todd Gillespie replied 19 years, 2 months ago 3 Members · 4 Replies
  • David Battistella
    July 26, 2007 at 4:15 pm
    Stills in the photoshop format or animation codec will always need rendering before output.
    You could also turn on dynamic RT.
    The Kona cards do not offer hardware acceleration for any of these types of effects. They are all handled by the MAC processor.
    The Kona only gives you some help with certain codecs.
    David
    Peace and Love 🙂
    Read my Blog
    https://blogs.creativecow.net/DavidBattistella
  • Richard Rodriguez
    July 26, 2007 at 6:13 pm
    David,
    Is there a way to nest the layers so that we can achieve real-time preview?
    Thanks…Rich
    BIG RICH
  • David Battistella
    July 26, 2007 at 10:39 pm
    the only way to achieve RT is by setting up RT in your timeline so that there is no longer a render. This will allow you to work in draft mode or resolutions and see FX.
    The other thing is to plan the workflow so that the things that you are importing match thte codec you are working in.
    David
    Peace and Love 🙂
    Read my Blog
  • Todd Gillespie
    July 27, 2007 at 12:32 am
    If I’m doing the math correctly…you have 12 layers with motion/animation? and you want constant realtime playback?
    I think you’re beyond the realtime capabilities of most edit systems, even for DV. I’m sure it’s not taking that long to render, but I do understand the frustration.
    The problem is that even though you only change one value on one layer, it changes the ENTIRE composite that FCP is doing, so of course it will need to re-render everything.
    Some edit systems will have a ‘processing heirarchy’ which will allow them to only ‘process (same as rendering)’ the layers that are above the changes. It’s very cool.
    The way you can achieve a similar workflow would be to ‘lock’ down the layers that you don’t need to change and create a movie/still of that composite, therefore cutting down on your total layers.
    Good Luck,
    Todd at UCSB
    Television Production
