  • Posted by Twann Hudson on June 10, 2009 at 2:14 am
    i having issue with rendering key out dv footage. i am using the plug in promatte keyer 4 on a 15 second piece of footage and it’s taking 20 min. does anyone have any suggestions?
    the real fun begins when the program loads
    running FCS 2 & CS3 MS side by side on the Mac
    Jerry Hofmann replied 17 years, 3 months ago 2 Members · 3 Replies
  • Jerry Hofmann
    June 10, 2009 at 1:07 pm
    About the only way to speed up renders is a faster CPU and GPU… What machine are you running?
    Jerry
    Apple Certified Trainer
    Author: “Jerry Hofmann on Final Cut Pro 4” Click here
    8-Core 3.0 Intel Mac Pro, Dual 2 gig G5, AJA Kona SD, AJA Kona 2, Huge Systems Array UL3D, AJA Io HD, 17″ MBP, Matrox MXO, CD’s
  • Twann Hudson
    June 12, 2009 at 5:22 am
    i’m using
    Mac Pro
    Processor Name: Dual-Core Intel Xeon
    Processor Speed: 3 GHz
    Number Of Processors: 2
    Total Number Of Cores: 4
    L2 Cache (per processor): 4 MB
    Memory: 4 GB
    Bus Speed: 1.33 GHz
    for such a small piece of video it seems to be taking to long to render
  • Jerry Hofmann
    June 15, 2009 at 1:17 pm
    You’d likely see a better workflow if you added some RAM to the setup if you want to run all those apps at the same time. Also might beef up your graphics card if it’s the stock card that came with that machine…
    Jerry
