Activity › Forums › Apple Final Cut Pro Legacy › Rendering
Rendering
Posted by Jasmine1919 on December 8, 2006 at 3:55 pmHello,
after digitizing some mini-DV and puting the footage on the timeline I can not work with it without rendering the footage each time… what happened? what can I do?
Don Greening replied 19 years, 9 months ago 4 Members · 4 Replies -
Steve Eisen
December 8, 2006 at 3:59 pmSequence setting.
Steve Eisen
Eisen Video Productions
Director-At-Large
Chicago Final Cut Pro Users Group -
Jim Carswell
December 8, 2006 at 4:15 pmIn other words your timeline setup has to match what you are digitizing.
JimJim Carswell
Spyhop Productions, Inc.
Savannah, GA
http://www.spyhopproductions.com -
Jasmine1919
December 8, 2006 at 5:38 pmDoes that mean that I ll have to re-digitize the footage making sure the setup is on dv-pal for the timeline as well as the project. I normaly easy setup, so I guess the timeline set up did not follow that one time?
do i make sense… what can i do is there any way of not having to re-digitize the footage?
Don Greening
December 8, 2006 at 8:16 pm[Jasmine1919] “do i make sense… what can i do is there any way of not having to re-digitize the footage?”
You won’t have to re-capture your video as long as your sequence settings match the type of DV you have e.g. if you have DV PAL video clips then make sure your sequence setting is also DV PAL.
– Don
“Please take a moment to fill out your profile, including your computer system and relevant software. Help us help you.”
