Activity Forums Adobe After Effects rendering
  • Posted by N8tracks on December 13, 2005 at 7:00 am
    Im getting these faint unwanted gridlines when ever i render an AVI or QT file. Its almost most like interlace lines but they are spread too far apart to be that.
    anyone know how to fix this?
    Steve Roberts replied 20 years, 9 months ago 4 Members · 4 Replies
  • Eric Steinberg
    December 13, 2005 at 10:20 am
    I don’t know if this is what’s happening to you, but I experienced something similar when there were vector stills in the project which came from a pdf file a client gave me. There was something about those files, although I don’t know what, so I replaced the stills with some that I re-saved in Photoshop, and the lines went away. If your lines are only on stills, try replacing them with different (better) ones.
    Kind regards,
    Eric
  • Filip Vandueren
    December 13, 2005 at 1:59 pm
    It could be that there is a slight imperceptible dither in your imported file, that you don’t notice, but that your export codec trips on that…
  • N8tracks
    December 14, 2005 at 3:06 pm
    Is it because im at 8 bit?
  • Steve Roberts
    December 14, 2005 at 3:17 pm
    Not likely, in my opinion. 8-bit can cause banding. To picture that, imagine the difference between a smooth rainbow and one separated into 8 stripes. The 8-stripe one would suffer from an extreme case of banding.
    Do you have a field-rendered source clip that has been scaled up or down? If so, you need to reinterpret the file (file>interpret footage>main) and separate the fields. DV NTSC uses lower field first, by the way.
    If the source came with those lines, it may have been scaled before it got to you — in that case, you’d be, er, hosed.
    Got a still?
    Steve
