Activity Forums VEGAS Pro Rendering 1920 x 1080 to DVD
  • Rendering 1920 x 1080 to DVD
    Posted by James Dubendorf on November 15, 2011 at 2:20 am
    Hello,
    Let me apologize right off the bat for this post. I realize there are numerous forum discussions on Creative Cow about this question, but I can’t find one that answers my precise concerns. My Vegas project contains sound, still photographs, text and graphics, and 60i 1920×1080 footage from a Canon hfg10 converted to AVI through Neoscene. I have been editing the project using Vegas’ HD 1080-60i template in Project Properties.
    Previous renders that remain in 1920×1080 resolution such as the Sony AVC template look great. Unfortunately, I must now burn it onto a dvd to play on dvd players.
    My question is: how to get the most out of DVD’s 720×480 pixels? I know that starting with HD resolution then down scaling is better than never having been HD at all, but it really is such a bummer!
    1. If I plan to render in widescreen 720×480, should I change my project properties after editing but before the render to match the render settings? What happens if I retain the current project properties, but render using the DVD Architect NTSC Widescreen video stream template?
    I have experience rendering with the DVD Architect NTSC Widescreen video stream MPEG-2 template, but never from HD to SD. I just realized that if I change the project settings to NTSC DV Widescreen, two small margins appear on each side of the 1920×1080 images in the preview screen. Darn that 1.2121 pixel aspect ratio. Is there a fix here?
    2. Is there any advantage to not changing my project properties, rendering to another file type or template, and letting DVDA rather than Vegas do the compressing? I may be misreading, but this thread (https://forums.creativecow.net/thread/24/899003#899185)appears to recommend this strategy.
    3. Are there any strategies I can employ in the editing phase to improve quality (i.e. converting to broadcast colors, turning on the reduce interlace flicker feature for stills or video, etc.)
    Thank you for your assistance.
    James
    James Dubendorf replied 14 years, 10 months ago 2 Members · 2 Replies
  • Danny Hays
    November 15, 2011 at 8:49 am
    You can fix the small side piller issue by project settings, check Ajust media to better match project or render settings, It worked for me. I was suprised though when I tested rendering a SD mpeg for DVD from Vegas with the project settings set to match the HD footage, then just changed the projedct settings to SD widescreen for DVD and the files were identical in size and quality. With the settings set to HD, the editing looks great so I would do it that way. I used a 1080 60p video of a tiger and the SD widescreen video from it look fantastic for SD though.
  • James Dubendorf
    November 15, 2011 at 4:11 pm
    Danny,
    Thanks for the response!
    Am I reading correctly that you’ve had good results keeping the project settings in HD while rendering to an SD mpeg for output to DVDA and viewing on DVD?
    I am anxious about allowing Vegas to adjust media because I have a few different tracks carefully coordinated together involving text, arrows, etc.- if one track changes while the other stays the same, it may cause more problems than it solves. I have also considered rendering the entire project as a neoscene AVI, bringing that file into a new project, then applying certain effects such as color correction to the entire track, and perhaps zooming out a bit to correct the side pillar issue and account for overscanning.
    Best,
    James
