Rendering 16:9 aspect ratio footage
David Shaw replied 18 years, 2 months ago 5 Members · 17 Replies
Pete Fischer
May 8, 2008 at 12:29 amDanny and Mike: Thanks for all your thoughts and help!
I got Sony Vegas Movie Studio Platinum 7.0a (Build 52). When I ‘go to’ Render As on the File pull-down menu, there IS an Custom … button on the window that pops up. (Between the Cancel and the About … button.) It’s just that it is ‘under-highlighted’/not available.
Other items that are ‘under-highlighted’/unavailable in that window are “Save project as path reference in rendered media” and “Copy and trim media with project.”
But, let’s say Sony had de-activated this functionality for the Movie Studio version: Should we really believe that Movie Studio wasn’t capable of rendering 16:9 footage?
Another astonishing fact is that I CAN render a 16:9 DVD NTSC video stream (by going the Make Movie route and chosing the DVD NTSC video stream template)… but the result doesn’t have audio/is a ‘silent movie’. I still hope that there is a path to success.
I’ll wait for your feedback before uninstalling and re-installing Vegas.
Thanks, again,
Pete
Mike Kujbida
May 8, 2008 at 1:16 amPete, I use the full version of Vegas so I have no idea what Movie Studio leaves out.
First of all, check and see if you have the “DVD Architect NTSC Widescreen video stream” template option.
Next, since you don’t have any audio, see if there’s an AC-3 option in the “Render as type” box.
This is the way the full version does it (separate render for audio that is joined with the video portion in DVD Architect).The two items you referred to are available in the full version ONLY when you do a “Save As”.
Lastly, you mentioned using the “Match Media Settings” option in your first post.
In the full version, you can set this option (NTSC DV Widescreen (720×480, 29.970 fps) in the Properties” (File – Properties) template box.
Once again, I’m not sure if Movie Studio gives you this option. -
Pete Fischer
May 9, 2008 at 2:33 amMike,
Thanks for your thoughts and suggestions.
Yes, in “Render As”, I have a Template called “DVD Architect NTSC Widescreen video stream” … which gets me a ‘silent movie’ … but with the aspect ratio I want.
Yes, in “Render As”, under “Save as type”, I can choose “Dolby DigitalAC-3 Studio (*.ac3)”
Wow. So are you saying that – if I want to end up with 16:9 footage – I should, first, render a silent video stream and, then, render an AC3 audio stream and, later on, in DVD Architect somehow combine them?
If doable, that sure is better than not being able to maintain 16:9 aspect ratio – for sure! Yet, isn’t it odd that, if I go for 4:3 footage, the process is much more user-friendly? (Just thinking out loud… )
What do you think?
Regarding your last remark (“Lastly, you mentioned using the “Match Media Settings” option in your first post.In the full version, you can set this option (NTSC DV Widescreen (720×480, 29.970 fps) in the Properties” (File – Properties) template box.Once again, I’m not sure if Movie Studio gives you this option.”):
Yes, in my Movie Studio version I can choose the “(NTSC DV Widescreen (720×480, 29.970 fps)” template … in addition to setting the Pixel ratio to “1.2121 (NTSC DV Widescreen)”. The puzzling/frustrating thing is that I have learned how to make 16:9 footage show up as 16:9 – while editing it within Movie Studio. But when I am done editing and everything looks perfect and I want to render the thing, it ‘snaps’ back to 4:3 with those black bars on top and bottom.
Many thanks, as always,
Pete
Mike Kujbida
May 9, 2008 at 2:51 am…if I want to end up with 16:9 footage – I should, first, render a silent video stream and, then, render an AC3 audio stream…
This is the usual render procedure for anything you want to make into a DVD, not just 16:9.
Give both files the same name (eg. myvideo.mpg & myvideo.ac3) and render both to the same folder.
That way, when you load the video stream into DVDA, the audio will automatically follow.But when I am done editing and everything looks perfect and I want to render the thing, it ‘snaps’ back to 4:3 with those black bars on top and bottom.
Are you selecting “DVD Architect NTSC Widescreen video stream” in the Render Template box?
How do you know it “snaps” back?
Are you burning it to a DVD and watching it on a widescreen TV? -
Pete Fischer
May 9, 2008 at 5:15 pmThanks, Mike!
To be honest, I havent’ burnt a DVD yet with DVD Architect. So I’ll take your advice to heart.
As for the “snapping back”. Here’s my experience:
When I import a 16:9 video into Vegas Movie Studio, by default Vegas makes 4:3 footage (with black bars on top and bottom) out of it as indicated in the video preview window. I can change this – either before or after importing the video – by using File + Properties, Video tab and either the Match Media Settings button or choosing the 1.2121 Pixel Aspect Ratio and/or the “NTSC DV Widescreen (720×480, 29.970 fps)” Template as I now now. If I do that, I see 16:9 footage in the video preview window (without any bars).
I can then edit the footage to my heart’s content and everything looks fine (in the video preview window). And one would think that I have set the properties for this project once and for all. But not so:
When I, once content with the results of my editing, want to render the project – via Make Movie or File + Render As – at the very moment that the rendering starts, the footage in the preview window ‘snaps’ from 16:9 without bars to 4:3 with bars. And when I, once the rendering is done, view the result in either Windows Media Player or the VLC Media Player, I also see 4:3 footage with black bars on the top and bottom.
So that’s what I meant by ‘snapping’ (back) to 4:3.
Many thanks, again,
Pete
Nicolas Bergeron
June 27, 2008 at 11:14 pmI have exactly the same problem. Do you have further explication about this issue?
thx
Nicolas -
David Shaw
July 7, 2008 at 11:57 amI too have EXACTLY the same issue, but I am working in PAL not NTSC, but exactly the same frustration. Have tried all options to get a full screen 16:9 result even though the preview is in 16:9 and is perfect, inc photos, titling etc etc.
It was frustrating reading this post to see at the very bottom still no result. Doh!
David
