Activity › Forums › Adobe After Effects › rendered video too small
  • rendered video too small
    Posted by Mike Vonner on August 16, 2010 at 4:59 am
    i have an HD after effects file that is HUGE, 3 gigs. when i try to re-render it in windows movie maker in 720, it gets very small…how can i keep it full screen but keep the file size and resolution of acceptable size and quality
    Karl-jason Mawdsley replied 16 years, 1 month ago 3 Members · 2 Replies
  • Tudor “ted” jelescu
    August 16, 2010 at 11:35 am
    Use Adobe Media Encoder- H264 compression is pretty good ( you have presets that you can apply).
    Tudor “Ted” Jelescu
    Senior Compositor/VFX Artist
    Bucharest, Romania
  • Karl-jason Mawdsley
    August 17, 2010 at 4:21 pm
    When rendering from After Effects make sure your specifying the right compression. The default is usually animation which is always pretty big as it’s pretty much uncompressed video. Before hitting ‘Render’ click on the orange text to the right of where it says ‘Output Module’.
    Here you can specify your format and compression. Quicktime movie is normally the best format. To specify your compression, click on ‘Format Options…’ and you’ll see a range of different compressions you can use. The one you choose all depends on what your using your final video for. If you let me know I’d be happy to help you with some settings.
    KJ
