Activity Forums VEGAS Pro Rendered Vid doesnt work like source video does…
  • Rendered Vid doesnt work like source video does…
    Posted by Chris Forsyth on May 5, 2010 at 4:58 am
    Ok, so here’s the situation:
    I used Youtube Downloader to download the hi-res version of a short film I appeared in, because I wanted to edit it (add end credits scroll to it).
    The source material from Youtube Downloader ended up being an 82mb mp4 file. I brought it into Vegas Pro 9.0, and set the project properties to match the source material properties (see all of this below). I did the editing I wanted, and rendered to the same type of file format with the same attributed as the source material. First – the resulting file is half the size of the source material – and I have added about 30 seconds of scroll / music / background pic to the file. I didnt want it to be smaller or compressed or compromised in any way. Secondly, when I play the rendered file either in Quicktime Player or Win Media Player, it will play fine, but if I try to move the progress bar in either direction – it will move – but the video will freeze for about a minute or more, until it finally starts playing, and sometimes it doesnt play in sync from that new point – the audio will play – but the video is frozen. It’s almost like when I move the play progress bar – it is having to search for the material or something…it’s stalled until a minute of so later, when it will start playing again.
    More details:
    Computer: Windows 7 64bit, brand new, Intel Core i7 CPU, Q720, (i believe this is a quad core) @1.60GHz, 4GB RAM.
    Vegas Pro 9.0c
    All info and settings are as follows. Please take a look and see if I have done something wrong:
    SOURCE MATERIAL INFORMATION:
    (by right clicking on video track and selecting properties):
    – Use Timecode In File: SMPTE Drop (29.97 fps, Video)
    – Stream: Video 1
    – Format: AVC
    – Attributes: 1280x720x32, 5:35
    – Frame Rate: 29.97 (NTSC)
    – Field Order: None (Progressive Scan)
    – Pixel Aspect Ratio: 1.0000 (Square)
    – Alpha Channel: None
    – Rotation: 0 (Original)
    – Streams
    Audio: 00:05:35.853, 44,100 Hz, Stereo, AAC
    Video: 00:05:35.902, 29.970 fps progressive, 1280x720x32, AVC
    PROJECT PROPERTIES SETTINGS
    VIDEO TAB
    – Template: HDV 720-30p (1280×720, 29.970 fps)
    – Width: 1280
    – Height: 720
    – Output Rotation: 0 (original)
    – Frame Rate: 29,970 (NTSC)
    – Pixel Format: 32-Bit Floating Point (full range)
    – Compositing Gamma: 1.000 (Linear)
    – Full-resolution Rendering Quality: Best
    – Motion Blur Type: Gaussian
    – Deinterlace Method: Blend Fields
    AUDIO TAB
    – Master Bus Mode: Stereo
    – Number of Stereo Busses: 0
    – Sample Rate (Hz): 44,100
    – Bit Depth: 16
    – Resample and Stretch Quality: Best
    RENDER SETTINGS:
    – Save as type: MainConcept AVC/AAC (*.mp4) – same as source
    – Template: Custom Template as follows:
    — Frame Size: Custom Frame Size…Width 1280 Height 720
    — Profile: Main
    — Frame Rate: 29.970
    — Field Order: None (Progressive scan)
    — Pixel Aspect Ratio: 1.0000
    — Number of Reference frames: 2, Use Deblocking Filter checked
    — Variable Bit Rate: Two Pass checked,
    — Maximum bps (tried at 768,000 and 14,000,000)
    — Average bps (tried at 768,000 and 10,000,000)
    — The 768000 settings resulted in a 42MB file, the 10/14 million settings resulted in a 125MB file – both files experience the same problem in playback
    — AUDIO Tab: Include Audio, Sample Rate 44,100, Bit Rate – tried 128000 and 192000 – this made no difference
    — PROJECT TAB: Video rendering quality: BEST
    Thats all the information I can think to give. Basically what I want to accomplish, is to take the source material, add a few title cards at the beginning and a credits scroll, and then render the file in the exact format it started in and then re-upload it to YOUTUBE again – without losing any quality, etc.
    But for some reason – the output file was 42MB (compared to the source material 82mb). When I upped the variable bit rate settings to 10/14 million (max / average), it resulted in a 125MB file. But both files rendered experience this problem playing. I don’t know if I am missing something or what. But I am out of ideas.
    Any help is GREATLY appreciated!
    Chris
    Best,
    Chris Forsyth
    John Rofrano replied 16 years, 4 months ago 4 Members · 7 Replies
  • 7 Replies
  • Douglas Spotted eagle
    May 5, 2010 at 8:53 am
    Not possible to render from low bitrate MP4 to mp4 without suffering loss, unfortunately….
    Douglas Spotted Eagle
    VASST
    Certified Sony Vegas Trainer
    Aerial Camera/Instructor
  • Luke Wensing
    May 5, 2010 at 9:51 am
    What have I done wrong.I am ready to render and notice that mytimeline has pink segments (both audio and video). Ok, i try to render and a message comes back asking if i have access to the file at the time the pink starts…any clues? (render stops) (yes i did see those pink araes while working but I though it was just track colour.)
    Luke Wensing
  • John Rofrano
    May 5, 2010 at 12:39 pm
    I would use Sony AVC instead of MainConcept AVC. It may solve your playback problem. As Spot said, you will still loose quality because you have to re-render to add anything to the video.
    ~jr
    http://www.johnrofrano.com
    http://www.vasst.com
  • Chris Forsyth
    May 5, 2010 at 5:20 pm
    John:
    BINGO!!!
    That did it!
    Cant thank you enough.
    Funny thing is, just using the default settings for that render option resulted in a 287MB file, vs the 87MB file that I started with. Maybe the default bitrate of 6mbps makes it that big? Not sure what it is – but the playback works wonderfully! Thanks so much again John.
    Best,
    Chris Forsyth
  • John Rofrano
    May 5, 2010 at 5:35 pm
    You’re welcome. The bit-rate is directly related to the file size. I usually use 3.5Mbps for most internet video and it looks fine.
    ~jr
  • Chris Forsyth
    May 5, 2010 at 6:15 pm
    Aah…good to know…I’ll render one out at that bitrate and see what that gives me in file size. I’ve never uploaded anything to YouTube, so I don’t know if there are any file size limitations. I’m guessing that the larger the file size, the longer the buffering time for the viewer?
    Best,
    Chris Forsyth
  • John Rofrano
    May 7, 2010 at 2:18 am
    Yes, YouTube has file size limitations. Videos can be up to 2 GB in size and up to 10 minutes in length.
    Yes, indirectly. It’s really the higher the bit-rate the longer the buffering time.
    ~jr
