Activity › Forums › Adobe Premiere Pro › Rendered text unreadable
  • Rendered text unreadable
    Posted by Yunal Sobu on February 11, 2010 at 11:54 am
    Hi everyone.
    I’m rendering a small presentation of a sequence with lots of a text in it. I’ve tried the most discussed presets in this forum but still not getting even a readable results. I’ve also tried different types for the text (psd, jpeg, tiff)- still no results, so I’m running out of ideas.
    Any advice will be appreciated!
    Thanks in advance.
    Yunal Sobu replied 16 years, 7 months ago 4 Members · 7 Replies
  • 7 Replies
  • Mike Velte
    February 11, 2010 at 12:04 pm
    A picture is worth a thousand words…upload a high quality jpeg to us. Use the “File Upload” button just below the word “Message” in a post reply.
    Also what is your sequence resolution?
  • Yunal Sobu
    February 11, 2010 at 12:30 pm
    Format: H.264
    Preset:NTSC DV Hq – only changed the resolution to 800×600 in order to match the resolution of the images.
    The only other seting that I changed, is the pixel aspect ratio – to square pixels.
    Thank you Mike for your quick respond!
  • Mike Velte
    February 11, 2010 at 1:54 pm
    If this is your source file for Premiere??, the text is really poor. Below is a screen shot of an H264 video at 720×480. It began in Photoshop as a video preset 720×480 and then into a DV NTSC sequence, exported as H624 720×480;
    541_testfont2.jpg.zip‘>541_testfont2.jpg.zip
  • Yunal Sobu
    February 11, 2010 at 2:40 pm
    That was a screen shot from a video, just to show how bad the situation was, but I think I found the problem – changed the font to Tahoma (find this suggestion in thread with similar problem).
    Thank you very much for your quick help! Greetings from sunny Varna, Bulgaria.
  • Jeff Pulera
    February 11, 2010 at 4:25 pm
    Hi Yunal,
    You didn’t say how your presentation will be displayed – is this for computer playback, DVD, internet? If DVD, you need to watch the “title safe area” – the text is very close to the left edge and will likely get cut off on TV screens. For DVD/video output, do not change the DV project preset size, if NTSC then leave at 720×480.
    The fonts are pretty small for video, bigger is better.
    FYI, “suply” should be “supply, ned is need, and busines is business.
    I don’t speak a second language, so not being critical, just helping
    Jeff Pulera
  • Alan Lloyd
    February 11, 2010 at 6:47 pm
    I’d also skip the hyphenations.
    Other than that, yes, larger first, reposition, and do check spelling.
    Split it into two pages if necessary. Readable is better than a long time on one page.
  • Yunal Sobu
    February 12, 2010 at 7:55 am
    Thanks folks! I really do appreciate your help! I saw the wrong spelling, too (shame on me). Otherwise I’ll apply all your advices and let you know the result.
    Once again – thank you for the time you have dedicated to help such a newbie as me.
    P.S.
    I almost forgot – the video is for computer playback.
