Activity Forums Apple Final Cut Pro Legacy Rendered Sequence only plays backed 1 second loop
  • Rendered Sequence only plays backed 1 second loop
    Posted by Brandon Adams on November 25, 2009 at 6:12 pm
    I’m not sure if this is a common problem. I wasn’t sure what keywords to search for. I’m having a problem with my rendered sequences. It seems to occur after I leave my workstation for a long time and FCP auto-renders the sequence. When I return, everything is rendered, except that when I play it, all I see is about 1 second of footage (actually probably just a few frames) looped indefinitely (very jerky motion). Sound plays as it should, but the picture just sticks on that loop.
    Anyone have any suggestions?
    Thanks (and please move to basics if necessary)
    -Brandon
    Rafael Amador replied 16 years, 9 months ago 2 Members · 2 Replies
  • Brandon Adams
    November 25, 2009 at 6:15 pm
    Hrm. Sequence was set to SafeRT. I switched to Unlimited RT and it played as it should. Switched back to Safe RT and it now plays as it should. Not sure what causes this, but I suppose that’s a workaround.
    -Brandon
  • Rafael Amador
    November 25, 2009 at 6:26 pm
    Hi Brandon,
    Yu can uncheck the Auto-render in the preferences.
    rafael
    http://www.nagavideo.com
