Activity Forums VEGAS Pro Rendered project repeats
  • Rendered project repeats
    Posted by Kevin Pollock on May 28, 2019 at 6:36 pm
    I have created a project which is 1hour 39 minutes. After I burned the .avi to a dvd at the end of the show, it starts back from the beginning. In rendering I have render look region only checked and I don’t have
    Francois Pénzes replied 7 years, 3 months ago 2 Members · 2 Replies
  • Kevin Pollock
    May 28, 2019 at 9:11 pm
    I am thinking it may be that I used nero to create my dvd and I did not use a menu. Guess this could be causing it to loop back to the beginning.
  • Francois Pénzes
    May 29, 2019 at 12:12 am
    Hi Kevin
    You would have better luck if you posted your question on the DVD Authoring forum.
    https://forums.creativecow.net/dvdauthoring
    Cheers !
    PC Win 10 Pro 64-bit 16gb Intel® Core™i7-2600k Quad Core 3.40GHz
    Cameras: Canon XF305 + Canon XH-A1
    Blackmagic HyperDeck Studio Mini
    Vegas Pro 16, User since Vegas 3.0
    \’\’When the cutting stops, the editing begins…\’\’
