Activity Forums Apple Final Cut Pro Legacy Rendered items don’t stay rendered
  • Rendered items don’t stay rendered
    Posted by David Cooke on June 5, 2009 at 4:23 pm
    Noticed after rendering, winthin moments, red lines appear showing these items on the timeline
    need to be rendered. One time after rendering, hitting home to return to the head of the timeline yielded all those items showing up un-rendered. Later, after rendering, not even at the machine,
    they red lined-unrendered portions of the timeline “popped” back up.
    No pattern to this problem yet. Are the FCP Preferences corrupted, some “cache” memory too full.
    Deadlines are approaching, so any help would be appreciated.
    D’s Video
    Dino Vince replied 17 years, 3 months ago 4 Members · 6 Replies
  • Chris Borjis
    June 5, 2009 at 4:30 pm
    what version of final cut?
  • Shane Ross
    June 5, 2009 at 5:00 pm
    What type of media? Where is it stored?
    Shane
  • David Cooke
    June 5, 2009 at 6:40 pm
    Sorry about that, forgot to post the software and equipment used. We edit on a Dual 3.0 Intel.
    FCP is 6.0.5 OS is 10.4.11 with 4 Gig of ram, Aja LH, Caldigit 2.5T drives.
    DC
    D’s Video
  • David Cooke
    June 5, 2009 at 6:56 pm
    Sorry Shane. We are editing in standard def,usually footage from a DVCPRO50 Panasonic camera. Using
    After Effects 8.0.2 Photoshop CS3 usually a ‘couple of layers’. We edit alot of car commercials.
    thanks,
    D’s Video
  • Shane Ross
    June 5, 2009 at 7:10 pm
    Hmmm…I’d trash prefs then.
    Shane
  • Dino Vince
    June 5, 2009 at 7:34 pm
    are you moving the clips on the timeline? moving them can cause this ‘unrendering’ problem. Also, might want to check that your sequence settings and your footage settings match? Trashing preferences and restarting might help too. Take heart that when you export, the exported file should be fine. Hope this helps. Good luck
