Activity Forums Maxon Cinema 4D Rendered Images not in directory
  • Rendered Images not in directory
    Posted by Michael Gibson on September 22, 2009 at 4:25 pm
    This has happened a couple times in the week. I have set my Save settings in the Render Globals to my project folder but the images are not saving to it. I have double checked my out put path and it is correct. My machine is rendering right now but I can’t find where they are going. If anyone as any ideas that would be awesome. Thanks
    Tim Shetz replied 17 years ago 2 Members · 3 Replies
  • Tim Shetz
    September 22, 2009 at 5:34 pm
    This may sound like a stupid suggestion, and I apologize in advance if it does, but this happens to my students quite often. Since you know the name of the file it should be rendering, you can do a file search to look for it. Then at least you can see where it is going if not why.
  • Michael Gibson
    September 22, 2009 at 7:54 pm
    Thank for the advice but I’ve done a search using the naming convention. They are no where to be found. It is really driving me crazy. Thanks for your time.
  • Tim Shetz
    September 22, 2009 at 8:10 pm
    Can you take screen shots of your render settings? There might be a clue somewhere…
