Activity Forums Apple Final Cut Pro Legacy rendered file will not go away
  • rendered file will not go away
    Posted by Ron Norris on January 14, 2009 at 11:27 pm
    Hi all, I have a weird question. Have you ever rendered a file on the timeline, then deleted that file and replaced it with another one… only to find out that there is a 3-5 frame remnant of the original rendered file that will not go away? I have tried everything… re-rendering the new file, moving things around… etc. Funny thing is, if there is nothing on v1 (just blank space) the remnant doesn’t show up, as soon as I place something in that exact spot the remnant reappears! This is happening in two spots on my timeline. I can’t get rid of it, it just shows up during playback like it’s part of the timeline.
    Any help is greatly appreciated… I need to figure this out so I can get the final done.
    FCP 6.03, macpro 8 core, 8 gig ram, 8 TB storage
    thanks again… I need help!
    Ron
    Ron Norris replied 17 years, 8 months ago 3 Members · 5 Replies
  • Richard Sanchez
    January 14, 2009 at 11:31 pm
    You could use your Render Manager to blow away all of your render files, but if you’re talking about a large sequence that would require a long time to re-render, that’s probably not what you want. Did you trash your preferences?
    Richard Sanchez
    North Hollywood, CA
    “We are the facilitators of our own creative evolution.” – Bill Hicks
  • John Pale
    January 15, 2009 at 3:11 pm
    The sequence is probably corrupt. Create a new empty sequence, copy all clips from the old one to the new one and see if your problem disappears.
  • Ron Norris
    January 15, 2009 at 3:25 pm
    Thanks for the help guys… I’ll try what is suggested and let you know
    thanks again
    ron
  • Ron Norris
    January 15, 2009 at 4:42 pm
    Richard and John, thanks. Simply making a new sequence did the trick.
  • Ron Norris
