Activity Forums Adobe Premiere Pro Rendered clip must be re-rendered when copied/pasted to new sequence
  • Rendered clip must be re-rendered when copied/pasted to new sequence
    Posted by Valter Mac on August 26, 2009 at 8:32 am
    When I copy/paste rendered clip to new sequence (with same settings) I must render it again. Is this bug, or…?
    Vince Becquiot replied 17 years ago 2 Members · 3 Replies
  • Vince Becquiot
    August 26, 2009 at 3:23 pm
    Not really, render files are associated with each sequence. You will lose renders if you nest as well.
    Vince Becquiot
    Kaptis Studios
    San Francisco – Bay Area
  • Valter Mac
    August 26, 2009 at 8:18 pm
    I’m not sure that I understand your reply…
    In Premiere CS3 if you put clip to sequence and add filters to it, then render it, it will take same preview files when you copy clip to another sequence.
    In CS4 you must re-render clip when it’s pasted to new sequence, even if it was rendered on the 1-st sequence.
    This is not bug but feature?
    Sorry for my bad English.
  • Vince Becquiot
    August 26, 2009 at 9:15 pm
    Well, I’m not sure it qualifies as a bug since the architecture behind sequences is vastly different in CS4.
    In CS3 you could only create identical sequences format wise.
    In CS4 you can do what could only be achieved with a new project in CS3.
    I would imagine keeping track on render files would be pretty complex to achieve in CS4 because of that new option.
    Vince Becquiot
    Kaptis Studios
