Activity › Forums › VEGAS Pro › rendered clip is not smoothly playing back
  • rendered clip is not smoothly playing back
    Posted by Jaanus Henno on November 19, 2007 at 7:45 pm
    Hello!
    Im trying to solve such an issue. Need to render one clip from a mpg video file. Settings of mpg show that field order is none (prog. scan). So when rendering with the same settings or I also tried all other options (cause Im not quite clear how its actually working) like blend fields, lower-upper field first, but nothing changed. After rendering, parts where is quick motion look like few frames are left out of the clip, movements are robot-like(not slower, but chopped), not smooth.
    How to fix that or render so that it would not occur?
    Thank you for any advice.
    Regards,
    Srivas
    Jaanus Henno replied 18 years, 10 months ago 2 Members · 2 Replies
  • Terry Esslinger
    November 19, 2007 at 8:19 pm
    You didn’t give specifications but perhaps your computer is not stout enought handle the size/bit rate of the rendered file?
  • Jaanus Henno
    November 20, 2007 at 8:47 am
    I just found the answer. It came out that its not the problem with Vegas or computer. Its windows Media Player fault. I tried to play in winamp and everything is ok now. Although I have no idea why media player is doing that. Looks like I have to do some research and get some good player.
    Thanks anyway.
