Activity Forums Adobe After Effects Rendered Cineon Wrong Length
  • Rendered Cineon Wrong Length
    Posted by Jason Mckee on January 4, 2008 at 6:39 pm
    Alright… I have to admit, it’s kind of embarrassing how many questions and posts I have had lately but I hope my questions have helped someone out there besides just me.
    Okay so with that said heres my “New” problem. I am doing a credit roll in 2k and having to convert it into Log Space for the film out (this is how I have to deliver it), since there are graphics in the credit roll. I am using the Cineon Converter found under utilities to accomplish this. This is probably not the problem I am just trying to give as much detail as possible. So at the beginning and end of my composition I have exactly one frame of black before you start to see the credits roll. When I render this out I have it set to Comp length not work area. My comp is 3:30:00 long. The final rendered Cineon Sequence ends up being that exact length but my credits don’t actually appear until about a second and half to two seconds from the beginning and end. Whats the deal? The frame rate is 23.976. I have checked all my settings on output and on import. Everything seems to be fine. Thanks in advance for your help.
    Darby Edelen replied 18 years, 8 months ago 3 Members · 3 Replies
  • Joel Jackson
    January 4, 2008 at 6:48 pm
    Is it taking a second or so to get past title safe?
    Joel Jackson
    http://www.creativebloc.com/port.html
  • Jason Mckee
    January 4, 2008 at 9:54 pm
    No, it doesn’t even show up at the very edge of the screen until about 2 seconds in. It doesn’t make it to title safe until a couple of seconds later. It has to be something with the way it rendered or the settings I gave it. But as far as I can tell, theres nothing weird with the settings.
  • Darby Edelen
    January 5, 2008 at 6:15 am
    [Jason McKee] “The frame rate is 23.976”
    This may be unrelated, but if you’re delivering a Log Cineon Sequence why do you need to use a 23.976 frame rate? Why not 24? Is this intended for both Cineon and tape?
    If you render a draft mov is the timing correct?
    Also, to clarify, your credits don’t appear at all in the rendered sequence until frame 48?
    Darby Edelen
    Designer
    Left Coast Digital
    Santa Cruz, CA
