Activity Forums VEGAS Pro Rendered Audio file not the same ‘size’ as original
  • Rendered Audio file not the same ‘size’ as original
    Posted by Morgan Lewis on November 13, 2012 at 6:40 am
    My cousin and I have been playing around with recording audio and a few sessions he trailed away from the mic too much and increasing the mp3 by the 12DB didn’t really cut it, so I re-rendered it after it was increased by 12DB so I could increase it more.
    But if I place the new Mp3 file beside the old one, it’s 2 of the smallest unit of time (Not sure what to call them since it’s less than a second but there’s only 30 of them apparently). Shouldn’t a re-rendered audio file that’s only been edited in this way be the exact same size on the timeline?
    I’m just concerned that this slight increase might cause sync issues or something.
    John Rofrano replied 13 years, 10 months ago 3 Members · 2 Replies
  • Steve Rhoden
    November 13, 2012 at 10:50 am
    If you mean the length of them is different, that
    should not be, if you simply re-render a file. The
    only visual difference you should see is the waveform
    patterns (Waveform is those spikey graphics
    in the middle of the audio file
    ), that is normal.
    Steve Rhoden
    (Cow Leader)
    Film Editor & Compositor.
    Filmex Creative Media.
    https://www.facebook.com/FilmexCreativeMedia
    1-876-832-4956
  • John Rofrano
    November 14, 2012 at 1:44 am
    [Morgan Lewis] “Shouldn’t a re-rendered audio file that’s only been edited in this way be the exact same size on the timeline?”
    Not if it’s MP3. That’s a very lossy codec. You should be working with WAV files if you are worried about quality. You should also use Normalize to solve your volume problem instead of increasing the volume by 12dB.
    ~jr
    http://www.johnrofrano.com
    http://www.vasst.com
