Activity Forums Adobe After Effects Render with optional alpha channel
  • Render with optional alpha channel
    Posted by Hannes Paulsson on August 4, 2011 at 9:52 am
    Hi!
    A client wants me to render a clip (lossless .mov) with an alpha channel. The thing is that he wants to be able to separate the alpha and see what’s behind, if you understand.
    Basically, he wants a 10 sec clip, where the first five seconds is transparent, but if you choose to ignore the alpha-channel you can see whats behind it.
    I have my clip and an alpha layer that i set with the “set channel” effect. When I render it out I choose “straight”.
    This almost work, when I import the rendered clip it works fine, but when i choose to ignore the alpha i only see about every 5th-10th pixel, the rest is all black.
    Sorry if this is confusing, english isn’t my first language and I’m a bit stressed.
    Hannes Paulsson replied 15 years, 1 month ago 39,338 Members · 1 Reply
  • Hannes Paulsson
    August 4, 2011 at 10:43 am
    Ah, figured it out. Didn’t use 32bits.
