Activity Forums Maxon Cinema 4D Render views
  • Render views
    Posted by Marc Lucas on March 12, 2011 at 4:29 pm
    I’m having a little trouble with rendering the right view.
    When working in perspective view I can see all the elements on the scene. What I want to do is render my spinning 3D text from the front view so I have it square on. What is the easiest way to achieve this because I have been trying to select the ‘Front” view but the renders still are coming out in perspective view.
    Brian Jones replied 15 years, 6 months ago 2 Members · 1 Reply
  • Brian Jones
    March 12, 2011 at 5:38 pm
    Use as Render View has to be enabled for the view you want to render. If you use the Front view it won’t be a perspective view though. If you want a straight on view that still has perspective it’s easiest to add a camera and just place it where you want. Or use a target camera so it points where you want. But it all depends on what you are really after for a look.
