Activity Forums VEGAS Pro Render to WMV 1920×1080 in VMSP 9?
  • Render to WMV 1920×1080 in VMSP 9?
    Posted by Jensen Harris on November 25, 2008 at 5:11 pm
    Hello,
    I have 1920×1080 footage shot on a Vixia HF11 camcorder.
    I would like to render it to WMV 1920×1080, but the highest available image size in the encoder settings appears to be 1440×1080.
    I can set “custom” and manually type in 1920×1080 as the output dimensions, but then my video gets rendered letterboxed instead of filling the frame.
    How can I render to WMV while keeping the 1920×1080 native resolution of the video?
    Thank you!
    Jensen Harris replied 17 years, 9 months ago 2 Members · 2 Replies
  • John Rofrano
    November 25, 2008 at 5:37 pm
    Did you set the Pixel Aspect Ratio to 1.000 (square)? At 1440 the PAR is 1.333 but at 1920 the PAR is 1.000.
    ~jr
    http://www.johnrofrano.com
    http://www.vasst.com
  • Jensen Harris
    November 25, 2008 at 5:59 pm
    Thanks for the reply!
    I did set it to square (1.0)
    The aspect ratio is correct in the final render, it’s just letterboxed on both sides unfortunately.
