Activity Forums Maxon Cinema 4D Render to Picture Viewer rendering from Right camera view instead of Perspective
  • Render to Picture Viewer rendering from Right camera view instead of Perspective
    Posted by Sam Bellamy on March 19, 2016 at 7:05 pm
    Hi! I’m fairly new to Cinema4D! When I finished making an animation I went to render to picture view and my render was coming out in the Right view camera instead of the camera I have in my workspace (which is linked to Perspective).
    I checked and the Object Attributes menu for my Camera object and the Projection in there is linked to Perspective. I have also checked the Projection for the Linked Camera in the viewport and it is also set to Perspective…
    However, I just realized when I press F5 to look at all my camera views it looks like I have messed them up a bit. One of the views is clearly a Right camera view but is labeled as Perspective! I assume this is the root of the problem I am having. Is there a way to reset this to the default camera settings Cinema4D initially came with?
    Brian Jones replied 10 years, 1 month ago 2 Members · 1 Reply
  • Brian Jones
    March 19, 2016 at 8:22 pm
    try going to Window/Customization/Layouts (or just use the Layout pop-menu in the upper-right corner) and chose Standard
