Activity Forums Adobe Premiere Pro Render to DVD Error
  • Steven L. gotz
    November 18, 2006 at 9:09 pm
    As far as I can tell, it is not a good idea to export to standard definition from an HD project. I recommend that you import the HDV project into a SD project, scale it down and export from there.
  • David Basulto
    November 18, 2006 at 9:19 pm
    thanks for the info! So start a new project and import the hd to a project with sd settings? or is there a lot more to it?
  • Steven L. gotz
    November 19, 2006 at 1:08 am
    That’s about it. The sequence you had in the old project can be brought on to a new sequence in the SD project. Resize it in one step and export.
  • David Basulto
    November 19, 2006 at 2:38 am
    many thanks!
