Activity Forums RE:Vision Effects Render times for Twixtor
  • Render times for Twixtor
    Posted by Pieco on November 15, 2005 at 8:36 pm
    I just tried the demo for Twixtor on Final Cut 5. The Mac was not as powerful as the ones I use at work, but still the render times seemed ridiculous. In general, are long render times for this plugin common? If so, I can deal with it, I just need to prepare my renders accordingly.
    Gene
    Peter Litwinowicz replied 20 years, 10 months ago 2 Members · 1 Reply
  • Peter Litwinowicz
    November 15, 2005 at 9:51 pm
    If you are getting 1 or so seconds computation per frame (30 times slower than real time) then what you are seeing is normal.
    As to the Pro version, if you don’t get fancy with plugins then I suggest just sticking with the regular version. The Pro version allows you to do things like provide mattes for foreground objects (that you must make by hand)…. If you don’t do a lot of manual work on images, then there is no need to buy the Pro version.
    Pete
