Activity Forums VEGAS Pro render times
  • render times
    Posted by Patti Arrigo on April 21, 2011 at 9:25 pm
    Hi My question is rendering time.
    should I do the multi cam first make my cut then do the chroma…color correction…and other effects after I have my cut done. Will that
    reduce the rendering time?
    Patti
    Patti Arrigo replied 15 years, 5 months ago 3 Members · 5 Replies
  • Daniel Hughes
    April 21, 2011 at 10:29 pm
    I don’t think it really matters what order you do things, if it’s still going to be be the same effects and output in the end. Vegas has the same amount of rendering work to do.
    There’s something about the wording that makes me think you’re getting mixed up with ‘rendering’ and ‘editing’ or ‘workflow’
    If you were talking about workflow, yes, you’re probably better getting all of the clips, events or shots cut they way you like, then start your work on the audio or move to effects and colour correction.
    If you do the effects before you cut it, your previews are going to be laggier and you’re going to make mistakes and then you’ll realise you don’t like the effects and colours you initially used and it’ll just be a big messy shambles!
    Daniel Hughes
    Amateur Writer, Director,
    Director of Photography
    United Kingdom
  • Patti Arrigo
    April 21, 2011 at 10:51 pm
    Hi Danniel Thanks
    Your right I was getting mixed up with rendering and editing and workflow. I haven’t learned to talk the talk yet. Your answer helped I understood exactly what you said. Thanks very much.
    Just a note. Your comment about doing the effects first before I
    cut it. (I have been doing that.) Talk about a mess a mess doesn’t describe how bad it got.
  • Daniel Hughes
    April 21, 2011 at 11:20 pm
    You’ll pick it up quickly!
    Glad that helped then :).
    Daniel Hughes
    United Kingdom
  • Danny Hays
    April 22, 2011 at 2:37 am
    I would chroma, color correct each camera in multicam mode and render. That’s one recompression. The more times you render, (recompress) the lower the quality gets.
  • Patti Arrigo
    April 22, 2011 at 3:51 am
    Thank you Danny
