Activity Forums VEGAS Pro Render TIFF sequence
  • Render TIFF sequence
    Posted by Andrew Turner on February 7, 2010 at 8:54 am
    Does anyone know of a way to render a TIFF sequence from vegas.? Could this be possible through a custom script.? i’ve searched but cannot find any
    Cheers
    Mike Kujbida replied 16 years, 6 months ago 4 Members · 6 Replies
  • Mike Kujbida
    February 7, 2010 at 10:51 am
    Your only two choices are JPG and PNG.
    If you really want TIFF images, then output as PNG and use a batch converter like the one built into IrfanView (it’s free) to do the conversion for you.
  • John Rofrano
    February 7, 2010 at 1:05 pm
    Try File | Render As… select Image Sequence as the Save as type and choose TIFF as the Template. You can also choose BMP, JPEG, PNG, TIFF, WMPhoto, DPX, and EXR. No scripts needed.
    ~jr
    http://www.johnrofrano.com
    http://www.vasst.com
  • Mike Kujbida
    February 7, 2010 at 5:28 pm
    John, Andrew should know that this is something that was added in Vegas Pro 9.
    When I saw your post, I thought I had messed up so I went back through the Pro 8 menu (what I still use most of the time) and couldn’t find it anywhere.
    A quick read of the Pro 9 release notes showed that I wasn’t going crazy 🙂
  • John Rofrano
    February 7, 2010 at 5:50 pm
    You’re correct Mike. Render as an Image Sequence was added to Vegas Pro 9.0. I assume that people are using the latest Vegas Pro software unless they say otherwise.
    ~jr
  • Bob Peterson
    February 7, 2010 at 8:58 pm
    I don’t know about image sequences since I’ve never used that feature, but I can say that Vegas has supported tif files for several years. My best recollection is at least as far back as version 6.
    I started using PNGs because, during the course of a project using lots of still images, Vegas was taking a very long time to reestablish its window after I had jumped to a different window such as Internet Explorer and was returning to Vegas. Someone told me that Vegas was calling Quick Time to reopen each tif image. I don’t know if that was true, but it prompted me to switch to PNGs.
  • Mike Kujbida
    February 8, 2010 at 2:06 am
    Bob, TIFFS do indeed make a call to QT which is why most of us, just like you, prefer PNG images instead.
