Activity › Forums › Adobe After Effects › render the front view!
Posted by Bender on February 15, 2007 at 3:01 amhi … have a comp with 3d layers … is it possible to render the front view … otherwise i got strange distortions when rendering the active cam view!
thanks a lot!
best
florianSam Moulton replied 19 years, 7 months ago 6 Members · 5 Replies -
Mylenium
February 15, 2007 at 8:18 amNo. 3D views are always rendered from the camera.
Mylenium
[Pour Myl
Jimmy Brunger
February 15, 2007 at 10:08 amYou could just use 3D layers but not put a camera in there?
*Production Studio Premium / *Combustion 3
Win XP Pro SP2 / Intel P4 3GHz / 2GB RAM / GeForce FX5200 / DeckLink Pro / Sony BVM-20G1E / DVS SDI Clipstation / 110GB boot/80GB media/600GB RAID-0 -
David Bogie
February 15, 2007 at 7:23 pmDeleting the camera will default to the front view, yes.
However, you cannot move it around like you can a camera.
The better solution is to learn how cameras work.bogiesan
Andrew Kramer
February 15, 2007 at 7:44 pmActually deleting the Camera doesn’t default to the front view, it’s still a camera view. Notice the ability to push things off into the distance. The real front view is orthographic and there is no perspective; think blueprint.
I’ve heard ideas before about making the camera really far away and zooming in but I have never tried it to achieve this effect.
Sam Moulton
February 16, 2007 at 5:52 amcreate a new camera. set the zoom value to something like 10,000, it will default to basically the same view you get with the front view. Then you’re set.
or… just use 2D only.
