Activity › Forums › Apple Final Cut Pro Legacy › Render Text Problems
  • Render Text Problems
    Posted by Jason Elliott on March 22, 2006 at 7:05 pm
    Hello all,
    I have found a work around solution for this problem but I would like to know if anyone else had it and how you fixed it. Recently working uncompressed a client of mines projects titles would have small green specks around the edges when FCP 5 rendered them. The text was created using the TEXT tool, and the green only showed up on screen when I used the drop shadow effect and rendered it.
    Jeremy Garchow replied 20 years, 6 months ago 2 Members · 3 Replies
  • Jeremy Garchow
    March 22, 2006 at 8:36 pm
    This is a bug with FCP’s 10 bit rendering.
  • Jason Elliott
    March 23, 2006 at 6:33 pm
    So the only way around this is rending my titles out with ALPHA channels and re importing them? Wow, what a waste of time. Hopefully they will fix this before they release the Intel Version.
  • Jeremy Garchow
    March 23, 2006 at 6:44 pm
    Agreed. If you are creating titles in another program such as photoshop, you need to create the drop shadows in there and then flatten them. Big pain in the bootie.
    https://www.apple.com/feedback/finalcutpro.html
    Please, b*itch, moan, and complain here. Hopefully this will be fixed soon.
    Jeremy
