Activity Forums VEGAS Pro Render template troubles.
  • Render template troubles.
    Posted by Jeff Schroeder on February 12, 2013 at 6:04 pm
    I need a render template for a TV station that will produce an .MTS file with AVC (Profile-high) and Mpeg-1, Layer-2 Audio. All the specs are as follows.
    Video Codecs Used: AVC
    Audio Codecs Used: MPEG-1 Audio layer 2
    File Format: MPEG-TS
    Total Stream BitRate: 11.0 Mbps
    Video Stream # 1
    Codec (Human Name): AVC
    Codec Profile: High@L4.0
    Frame Width: 1 920 pixels
    Frame Height: 1 080 pixels
    Frame Rate: 29.970 fps
    Display Aspect Ratio: 16/9
    Video Standard: NTSC
    Scan Type: MBAFF
    Colorimetry: 4:2:0
    Codec Settings {Summary): CABAC / 2 Ref Frames
    Codec Settings (CABAC): Yes
    Video Stream BitRate: 9 957 Kbps
    Bit Depth: 24 bits
    Audio Stream # 1
    Codec: MPEG Audio
    Audio Stream BitRate: 256 Kbps
    Audio Stream BitRate Mode: CBR
    Sampling Rate: 48.0 KHz
    Bit Depth: 16 bits
    It seems to me quite a few options are either greyed-out or have a drop-down box with only 1 choice. Does anyone know how to customize render templates for to accommodate the specs above?
    Any help is appreciated,
    Jeff
    2-Xeon X5680 @ 3.33, EVGA SR-2 Mobo, 48GB DDR3, GTX 580 3072MB, 16TB Attached Storage, Win7, Vegas 11 x64
    John Rofrano replied 13 years, 6 months ago 2 Members · 3 Replies
  • John Rofrano
    February 16, 2013 at 12:54 pm
    That spec is a strange request. Nobody uses AVC video with MPEG1 audio in an MPEG2 Transport Stream. You usually use MPEG2 video with MPEG1 audio as MPEG-TS or AVC video with AAC or AC3 audio as MP4.
    Ask the station what other formats they accepts. See if they accept XDCAM or MXF. They all accept multiple formats.
    While you’re at it you might ask them what encoder they suggest you use to make such a non-standard format as AVC video with MPEG2 audio in an MPEG-TS container. I checked Adobe Media Encoder and as soon as you select AVC video it only has options for AAC audio too just Like Vegas. As I said, that spec is very odd.
    ~jr
    http://www.johnrofrano.com
    http://www.vasst.com
  • Jeff Schroeder
    February 16, 2013 at 4:00 pm
    Thanks John,
    I thought it was kind of odd. But, with the mp4 spec being so loose maybe this was common for them.
    As it turns out they are new to HD and, I’m guessing, have not worked out all the kinks.
    Jeff
  • John Rofrano
    February 17, 2013 at 12:29 am
    [Jeff Schroeder] “As it turns out they are new to HD and, I’m guessing, have not worked out all the kinks.”
    At least they didn’t require you to send a tape. 😉
    ~jr
