Activity › Forums › VEGAS Pro › render template for 1280x720p 60fps avhcd video
  • render template for 1280x720p 60fps avhcd video
    Posted by Howard Steiger on May 25, 2014 at 11:09 pm
    i film with gh2 dslr. thats my file type. what would be my best render template in vegas12 for best quality dvd? thanks in advance
    John Rofrano replied 12 years, 4 months ago 3 Members · 3 Replies
  • Mike Kujbida
    May 25, 2014 at 11:22 pm
    If you want to make a regular DVD (i.e. not a Blu ray), the only render template you can use is MPEG-2 for your video and either AC-2 or WAV for your audio.
  • Howard Steiger
    May 26, 2014 at 4:56 am
    should i let it render in 29.970 fps or the 59.40 it was fimed in?
  • John Rofrano
    May 26, 2014 at 10:39 am
    [Howard Steiger] “should i let it render in 29.970 fps or the 59.40 it was fimed in?”
    DVD’s only support 29.970 fps, 25.000 fps, & 23.976 fps (24p). You have no choice but to render 29.970 fps to be compliant.
    You’re also going to have to disable resample on all of your events that contain 59.40 fps footage so that Vegas Pro doesn’t blend the frames. Select all of them on the timeline, right-click one of them and choose Switches | Disable Resample.
    ~jr
    http://www.johnrofrano.com
    http://www.vasst.com
